what is max boost from a t3t4
Old Jun 16, 2004 | 06:33 PM
86si's Avatar
Default what is max boost from a t3t4
I am getting 23psi from my t3to4b .48ar(not sure of comp. trim)it is maxed out,is it possible to get 27,28psi from a t3t4
Old Jun 16, 2004 | 06:38 PM
Forrest Gump 9's Avatar
Default Re: what is max boost from a t3t4 (86si)
You can crank it to 86 psi if you want, but it's gonna be all hot air. You gotta know what trim it is to know its efficiency.
Old Jun 16, 2004 | 06:41 PM
86si's Avatar
Default Re: what is max boost from a t3t4 (Turbo9Nut)
haha,what trim would produce more than 23psi?
Old Jun 17, 2004 | 06:44 AM
graphic's Avatar
i have the t3/t4 B h-3 comp trim .63a/r and a stage 3 exhaust and i was told not to run it above 25psi...
Old Jun 17, 2004 | 09:09 AM
99B16Si's Avatar
ive seen a T3/T4E with a 60-1 compressor wheel, .82ar turbine and a stage 5 wheel die at 24psi. it only made 4 my hp when it was turned to 26psi but it made 15 more ft/lbs because of its midrange flow.
around 22-25psi its about where all of them die out but the motor plays a large part i this also along with a other components of a setup
BOOSTIN1
Feb 18, 2006 07:18 AM
S2KP
Jul 7, 2004 03:40 AM
Ri5e
Mar 25, 2003 11:59 PM
