Small T3/T4
Old Mar 25, 2003 | 10:29 PM
Ri5e's Avatar
Default Small T3/T4
What 'small' T3/T4 turbo do you guys recommend for a 1.6 Liter SOHC NON VTEC.
I'm looking for something with a .48 a/r on the hot side. Not sure about compressor side. Shouldn't be too laggy and should make 200 WHP @ 10-12 PSI?
Or should I stick with a nice big T3?
Give me recommendations on sizes to make the HP figures that I want, thanks!
Old Mar 25, 2003 | 10:47 PM
Midwestrider's Avatar
Default Re: Small T3/T4 (4 Stroke)
Look at a 50trim on Compressor side w/ .48a/r (T04E/T3)
Old Mar 25, 2003 | 11:17 PM
Ri5e's Avatar
Default Re: Small T3/T4 (Midwestrider)
should the compresser housing be .50 a/r? or .60 a/r?
also what trim/stage should the turbine be?
Old Mar 25, 2003 | 11:26 PM
CzanSOHC's Avatar
.50 on the compressor housing, stage 3 wheel.
Old Mar 25, 2003 | 11:33 PM
Ri5e's Avatar
Default Re: Small T3/T4 (CzanSOHC)
is that what you have on your car? t3/t4 with a .50 on the compressor housing with a stage 3 exhaust trim wheel? also, what size should the compressor housing be? .50 a/r or .60 a/r? and what about exhaust housing, .48 a/r or .63 a/r?
Old Mar 25, 2003 | 11:59 PM
400mDRAG's Avatar
This is a honest answer. Most people in here go with what ever other people say or do. A small t3/t4 for a 1.6 sohc motor would be a t04b S trim comp with .48 a/r and stage 2 or 3 wheel. Even a .50 trim on a .60comp a/r is big for street use. if your going to be boosting 6-10 psi the t04b is a great choice. the .50 would be great if your boosting 15-20psi , which will require a built motor on sohc
Cat'sturboteg
Jul 15, 2007 11:22 AM
95%
Apr 15, 2003 11:35 AM
JalopySiR
Feb 7, 2003 06:48 PM
B00STeD
Aug 21, 2002 03:59 PM
Muckman
Jul 17, 2002 10:19 AM
