What Keepers
Old Nov 10, 2013 | 09:53 AM
Boyle.R's Avatar
Default What Keepers
I have bought some Supertech valve springs and there steel retainers. What keepers should I use with these? After a recent thread on here i'm a little worried about this. I'm using OEM Type R valves
Old Nov 10, 2013 | 09:59 AM
Muckman's Avatar
Moderator in Chief
Default Re: What Keepers
You email the manufacturer and you tell them the exact part numbers and they will instruct you.
Old Nov 10, 2013 | 10:00 AM
Runnerdown's Avatar
I've used the manleys and oem dozens of times. Have yet to see either fail or pull through the retainer.
Old Nov 10, 2013 | 10:03 AM
Boyle.R's Avatar
I guess this would be wise but still be good to hear from those who are running this valve spring combo and what keepers they are using
Old Nov 10, 2013 | 10:04 AM
Boyle.R's Avatar
Ok cool, I figured they would be fine with OEM keepers but said i'd double check
Old Nov 10, 2013 | 11:26 AM
wantboost's Avatar
Who is Mr Robot?
you need to tell supertech your part number, they have two different spring kits and each have different spring wire diameters and different inner/outer spring diameters for both spring kits, both inner and outer springs
Old Nov 10, 2013 | 11:56 AM
92cxturbo's Avatar
Manleys for peace of mind!
Beau Gotti
Oct 29, 2006 01:35 AM
A2gt35r
Oct 10, 2005 06:48 PM
edo
Apr 6, 2005 07:02 AM
mhgleitz
Nov 14, 2003 08:58 AM
