what injectors...
Old Nov 18, 2002 | 08:25 PM
BoostedH23a1's Avatar
Default what injectors...
h23 8psi boost stock block... going to run s200b...
Old Nov 18, 2002 | 08:27 PM
CzanSOHC's Avatar
Default Re: what injectors... (BoostedH23a1)
440cc.
Old Nov 18, 2002 | 09:41 PM
b16ahybrid's Avatar
I would bump that to 550's just incase you decide to run more boost later on down the road,it's always better to overbuild the set-up then to push it to the limits.
Old Nov 18, 2002 | 11:19 PM
DLB1994's Avatar
Default Re: what injectors... (b16ahybrid)
dsm 450cc
Old Nov 19, 2002 | 04:40 PM
Zenki James's Avatar
Default Re: what injectors... (DLB1994)
I think that if you run a peak and hold injectors, then I would go with a Cleaned up DSM injectors, more than enough to handle 8-10psi. If you have or think you might have some big plans get big nasty ones.
-James
Old Nov 19, 2002 | 05:37 PM
DeeJay's Avatar
New User
Default Re: what injectors... (Zenki James)
Help me too, Should I get peak/hold (550 cc) for my 94 h22a? I think my stock injectors are, i have a resistor box. What do i do if i get saturated (440 cc), remove the resistor box?
Old Nov 21, 2002 | 02:14 PM
Default Re: what injectors... (DeeJay)
dont i have to run peak hold with prelude resistor pack...
Old Nov 21, 2002 | 02:54 PM
Vanilla Ic3's Avatar
ya. Saturated are the ones that don't need the resistors.
BoostinTEG
Jan 22, 2011 06:34 AM
columbushatch
Jan 17, 2009 11:08 AM
FBP Si 2000
Dec 14, 2003 10:56 PM
sivik2nr
Jun 11, 2003 09:59 PM
