what i need for tuning
real newbie question here...did some research, read up on phearable.net...and i just want to make sure i have a clear understanding...so i got a whole 15g greddy kit and only thing i need is a obd1 ecu...im planning on getting a chipped ecu from phearable.net, and is that all i need once i plug it in with the obd2 to obd1 harness to drive to the tuner?? im planning on tuning with chrome, uberdata, or neptune which they dont need any special kind of add on to the chipped ecu like hondata s100/s200 right?? thanks
From: New York in the summer, South Carolina in the winter
If i were you, id find a way to disable the wastegate spring, so the car wont build boost. baby it to the tuner, then install a jumper cable, as well as a ecu, fuel pump, and injectors and your good to go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cilvia »</TD></TR><TR><TD CLASS="quote"> im planning on tuning with chrome, uberdata, or neptune which they dont need any special kind of add on to the chipped ecu like hondata s100/s200 right?? thanks</TD></TR></TABLE>
This depends on what tuners are in your area.
Some tuners won't tune on crome & it is for a reason.
I would recommend having the car tuned on hondata, ectune or neptune if you can afford it.
I am guessing you have the proper size injectors & fuel pump ?
Another thing to consider is your map sensor as the stock map sensor only reads up to 11 psi.
yea the spot i planned on doesnt wanna do chrome for some reason?? why would ectune and neptune be more expensive??
im only aiming for under 200whp so fuel pump i dont think i will change since i heard they are good untill over 220whp and injectors, im still trying to find some used 310cc...and hopefully i dont have to go over 11 psi for my power goals
G-Robinson
10
Feb 28, 2008 12:38 PM
