What goes here?
Can someone please tell me what goes in this hole that the arrow points to? do i get a fitting for this and run it to my external tial wastegate?
which fitting from this site to i need to put in there so i can run a hose to the wastegate?
http://www.atpturbo.com/Mercha...e=FTG
Who is Mr Robot?
you can either plug it with a 1/8th npt plug and run the boost source to your tial from the intake mani, or you could just go to home depot or lowes, buy a 1.8th npt nipple, put some teflon on it, screw it in and run your boost source from the compressor, although the actual psi the motor sees will be lower because of the pressure drop from the intercooler plus the cooler air charge
Mikey3000
Jun 4, 2008 07:26 AM
