Wastegate and boost solenoid hoses. How to run them?
I have a Tial wastegate and a Pro Logger boost solenoid. I'm a little confused on the interconnections between them and the engine/turbo. Can someone give me simple (a to b) type directions...lol. I'm also curious if I should run a line to the compressor or to the manifold and what fitting to use to tap the compressor if so.
TIA
TIA
Re: Wastegate and boost solenoid hoses. How to run them? (Mikey3000)
Port 1 goes to a pressure source (i recommend at the comp outlet somehwere) and to the bottom of the wg.
Port 2 goes to the top of the wg.
Port 3 gets the filter.
