What else is needed to have a good kit?
Old May 27, 2002 | 11:17 AM
integra-modder's Avatar
Default What else is needed to have a good kit?
Drag High flow 4 into 1 cast iron turbo exhaust manifold,
Turbonetics T4/T3 TO4E High flow turbocharger assembly,
Turbonetics Deltagate Mark II Wastegate (7 PSI Spring),
Greddy Type S Blow off valve,
Drag mandrel bent high flow chrome plated pipes,
Drag mandrel bent high flow exhaust down pipe,
Drag wastegaste dump tube assembly,
Drag Blue silicone hose and hose clamps,
Drag High pressure/High volume inline fuel pump,
Drag Boost dependent FMU fuel regulator,
Intake air filter assembly,
Map sensor bypass valves,
Stainless steel braided oil feed line w/ fittings,
Oil return assembly,
All nessasary hardware and fittings,
All nessassary hose and hose clamps,
All nessassary gaskets
Old May 27, 2002 | 02:28 PM
Default Re: What else is needed to have a good kit? (integra-modder)
i know you guys have some opinions to offer....
Old May 27, 2002 | 02:29 PM
i might just get the mugen one from king motorsports since its only 249...
Old May 27, 2002 | 02:57 PM
DIRep972's Avatar
Smarter than you
Drag manifold is good, but if u ever decide on going to a 3" downpipe set up u will want something w/ a more centralized wastegate, not on the 4th runner like the drag. It will cause boost spike in combination with the 3". something to think about
probably want to go with a tial wastegate. The deltagate has a reputation for failing after a few thousand miles.
Oil return assembly
the oil return assembly that comes with the kits is not the best. You may want to consider a steel braided line set up with areoquip or earls fittings.
Old May 27, 2002 | 03:14 PM
thanks....
Do you know of any ones thats are avaliable to buy? Or where do you get the areoquip or earls fittings
Old May 27, 2002 | 04:17 PM
Cramerox's Avatar
thanks....
Summit racing
Old May 27, 2002 | 04:21 PM
SlowB16's Avatar
Default Re: What else is needed to have a good kit? (Cramerox)
If I were you I would spend the extra money and buy everything seperate. Eventually you will want to upgrade anyways, so just spend the cash and do it now. For example: equal length manifold (or inline pro I think that name is)
Old May 27, 2002 | 07:28 PM
Default Re: What else is needed to have a good kit? (SlowB16)
whats a good name/brand/model for a turbo manifold for a T103/4E turbo? Will it work with the rest of the Drag Gen 3 turbo kit (piping, fitting, etc)?
Old May 27, 2002 | 09:07 PM
Cramerox's Avatar
This is what i would do- Buy the drag kit and buy a new manifold. You can either get the inline pro mani or the maxrev which will fit up just fine to the turbo. Plus they are both top quality. there are group buys going on for both of them.
The inline pro is casted and the maxrev is basically welded together. Both SS
The problem i ran into with my turbo setup was finding intercooler piping- the maxrev kit doesnt come with it altho it comes with an intercooler and some u-bends.
drag sells the piping but it cost 500 dollars piping is not hard to do but i just didnt want to deal with the hassel. I wanted to put the turbo in quick-didnt want to spend a day cuting and welding pipes together. I was lucky and found someone selling their piping for cheap.
but when i comes down to it- if you want hassel free get a kit. Drag will have everything you need. just upgrade manifold and better oil lines-like steel braids.
Old May 28, 2002 | 04:22 AM
Yea....drag is coming for around 2500 so its looking like a good deal...
whats the size of the downpipe on the drag?
Old May 28, 2002 | 09:13 AM
i know more people on this boards know about turbos....
Old May 28, 2002 | 12:14 PM
lswithvtec's Avatar
New User
the drag dp is 2.5 inch.
Old May 28, 2002 | 06:23 PM
Default Re: What else is needed to have a good kit? (lswithvtec)
where can i get the inline pro monifold for a good price?
Old May 29, 2002 | 02:30 AM
is there a good manifold that lets you keep your AC?
Tinberland21
Northeast (Sales)
17
Apr 7, 2008 08:37 AM
Tinberland21
Apr 6, 2008 06:19 PM
tha-Gr8-one8
Sep 21, 2005 03:41 PM
Fink2iCe
Aug 11, 2004 12:36 PM
NJTurboCivic
Jan 15, 2004 12:07 PM
