What on earth would cause this!
Old Jan 28, 2008 | 04:23 PM
  #26
GT4X-1's Avatar
Pics!
Block is fine though, just a little honing.
Old Jan 28, 2008 | 05:06 PM
  #27
ABK's Avatar
ABK
Default Re: (GT4X-1)
you might want to get the block bored over. IF you broke the ring land usually you get a nice notch on the thrust side that you can't get out with just honing. Also you piston skirts look little scored up, so your cylinder walls prolly don't look much better U also should not get crazy amount of piston slap. My buddy is running CPs in his gsr and it's barely hearable when it warms up (I mean you have to listen to it with a hood open). Take the block to the machine shop and have them bore the block to proper clearance that is set by the manufacture of the pistons for given application (n/a or boosted). Since you already blew your motor up twice I would suggest redoing the whole thing. Also somebody should retune your car.
Any damage done to the head? By looks of the piston it looks like some chunks hit the head.
Old Jan 28, 2008 | 05:25 PM
  #28
96 GSR-T's Avatar
I did this in my old motor, the cause of it was chunks of metal in the valve relieve area breaking off and getting shot out the exhaust, completely identical to what you got here, and my head was pretty chewed up too. Pistons were JE's and I was detonating bad, boost was around 13-14psi. Pull the turbine housing off your turbo, there is probably damage to the wheel.
Old Jan 28, 2008 | 05:30 PM
  #29
96 GSR-T's Avatar
how did you get an Auto ECU chipped? I was under the assumption Auto ECU's were not chippable/tunable.
Old Jan 28, 2008 | 06:12 PM
  #30
gunslinger's Avatar
From: Where thieves get shot in the face,, texas, usa
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunslinger &raquo;</TD></TR><TR><TD CLASS="quote">This happened to someone I know but it was caused by broken piston material hitting the plug</TD></TR></TABLE>
well i guess the assumption was correct piston material hit the plug!!!!
Old Jan 28, 2008 | 10:04 PM
  #31
ABK's Avatar
ABK
Default Re: (96 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">how did you get an Auto ECU chipped? I was under the assumption Auto ECU's were not chippable/tunable.</TD></TR></TABLE>
they are. I convered several ecus to manual. All you do is remove one resistor and solder in a jumper
Old Jan 28, 2008 | 10:17 PM
  #32
96 GSR-T's Avatar
Default Re: (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">
they are. I convered several ecus to manual. All you do is remove one resistor and solder in a jumper</TD></TR></TABLE>
I saw B & M Tranny Cooler so I am assuming he is running an Auto Tranny in the car, never heard much about hooking tranny coolers to Manual Honda Trannys.
Old Jan 28, 2008 | 11:30 PM
  #33
eg:R's Avatar
was the car tune??
Old Jan 29, 2008 | 01:42 AM
  #34
140sx's Avatar
get that greddy bullshit out of there...tune it with something not worth 2 engines
Old Jan 29, 2008 | 03:04 AM
  #35
Blind-Fashion's Avatar
Bad tuning caused all that damage
98couperc4
Apr 19, 2010 05:39 AM
Dave01
Feb 23, 2004 07:25 AM
Dave01
Feb 22, 2004 03:16 PM
