What does CFM stand for?
Old Jun 26, 2002 | 12:14 PM
LshatchTurbo's Avatar
New User
Default What does CFM stand for?
When discussing turbochargers, does CFM stand for "Cubic Feet per Minute?"
Old Jun 26, 2002 | 12:15 PM
falcongsr's Avatar
What is this crap?
Default Re: What does CFM stand for? (Zynentech)
yes.
Old Jun 26, 2002 | 12:41 PM
New User
Default Re: What does CFM stand for? (falconGSR)
So the more CFM a turbo can push, the more power in can create efficiently?
Old Jun 26, 2002 | 01:43 PM
dbman96's Avatar
New User
No, what's important is that it matches the CFM that your engine is consuming at the boost pressure you want. For example, 900 CFM won't do you jack squat on a 1.8 liter engine unless you're turning 30,000 RPM.
Old Jun 27, 2002 | 11:23 AM
symba's Avatar
Default Re: What does CFM stand for? (dbman96)
so how do you figure out how much CFM your engine can consume?
Old Jun 27, 2002 | 02:22 PM
dbman96's Avatar
New User
Default Re: What does CFM stand for? (symba)
MATH!
Engine displacement (L) * RPM / 2 * 0.03531 = CFM
example:
1.8L * 8000RPM / 2 * 0.03531 = 254 CFM
Old Jun 28, 2002 | 03:25 AM
kinesistech's Avatar
With a flow bench, you can measure how much air is moved at a given valve lift. With it you can determine how much power you will make at what rpm with what lift you want.
Old Jun 28, 2002 | 03:58 AM
symba's Avatar
Thank you...
DumpdEJ6
Nov 28, 2016 08:16 AM
gtimax
Aug 29, 2011 05:00 PM
mugen*ek9
Dec 13, 2005 06:02 PM
Gennady
Sep 24, 2002 04:34 PM
Dee
Nov 25, 2001 01:37 PM
