What Do You Think I Should Do?
Old Jan 10, 2003 | 07:57 AM
Fatty_1775's Avatar
Default What Do You Think I Should Do?
Damaged three pistons on my B16 with Revhard Stage 2c intercooled. Here are my choices...
Old Jan 10, 2003 | 07:59 AM
TheHater
Guest
Posts: n/a
Default Re: What Do You Think I Should Do? (import_racer)
Try import builders they have great packages check em out
Old Jan 10, 2003 | 08:42 AM
Fatty_1775's Avatar
Default Re: What Do You Think I Should Do? (TheHater)
Yes, Import Builders!!! Forgot about them. Thanks....
Old Jan 10, 2003 | 09:51 AM
avividmemory's Avatar
Yup, Import Builders does a really good job, also Viren does a good job...
just curious, but what exactly happened to damage 3 pistons? just some hardcore detonation or what?, and what about the head, is it thrashed too?
Old Jan 10, 2003 | 09:54 AM
BudaKai's Avatar
I'd learn how to do it yourself. That way you have more money left over for a bigger turbo.
I'd get it sleeved (GE harmless plug) , and build it with stock compression and tun it like a **** to get it at 10psi. You'll be out running every other set-up with 10psi and lower compression. You also woulcn't experience crazy lag like with lower compression. A definate plus would be a standalone. If you do drop compression you might as well get it sleeved anyways so you can crank up the fun.
Old Jan 10, 2003 | 10:46 AM
bgod's Avatar
Default Re: What Do You Think I Should Do? (tweeked3rdgen)
whatever you can afford within reason.
but rebuild with a tad bit lower compression would be my choice. 9:5:1 or even 10:1.
3easy21
Apr 2, 2013 12:25 PM
EdSales
Feb 9, 2010 07:01 AM
chapagetti
Apr 2, 2009 01:08 PM
civic-r11
Mar 31, 2009 12:04 PM
HarfordCTR
Dec 21, 2007 07:06 PM
