What do you guys think of this proposed setup???
Old Dec 19, 2001 | 04:59 PM
1's Avatar
Default What do you guys think of this proposed setup???
I want to use my B17A block (bored and sleeved to 84.5 mm), B20 crank, custom made rods to fit crank and short deck height, 84.5 JE pistons. This will produce a high revving fast piston speed engine but was told that fast piston speed is bad for FI. What do you all think would be the problem with this setup? Why would fast piston speed be bad? I am using my built B17A head as well with 10 p.s.i daily driver and maybe 15-20 p.s.i. at the track.
TIA
[Modified by 1, 6:00 PM 12/19/2001]
Old Dec 19, 2001 | 05:09 PM
BoM's Avatar
BoM
Default Re: What do you guys think of this proposed setup??? (1)
fast piston speeds wear the internals
why not get a new b20 block +some kinda girdle and new pistons and rods
and use a vtec head...
b20 crank creates a bad r/s ratio
Old Dec 20, 2001 | 05:35 AM
1's Avatar
Default Re: What do you guys think of this proposed setup??? (BoM)
anyone else?
Old Dec 20, 2001 | 05:40 AM
Arturbo's Avatar
Better than steak
25 Year Member
To be honest, I think you should just use what you have. Like my sig says, KISS. By keeping it simple I think my set up has done me very well and Im a big believer in keeping it simple. Just use the B17 and go from there. Work with what you have..
art
Old Dec 20, 2001 | 05:45 AM
1's Avatar
Default Re: What do you guys think of this proposed setup??? (Arturbo)
Art, I already have everything except the rods. I want the larger displacement and my B20 is toast. Maybe I could shave the top of the B20 off and weld it to top of the B17 and use standard rods. Now there's an idea.....
Old Dec 20, 2001 | 07:11 AM
BoM's Avatar
BoM
just turbo your b17a
Old Dec 20, 2001 | 07:22 PM
1's Avatar
Did you read my last post? I don't think my stock B17A bottom end is going to reach my goal of 350 h.p.. Does anyone have any solid ideas of what can be done with the my proposed setup?
Thanks again...
Junaid K
Jun 6, 2014 10:23 PM
salyboy25
Jun 10, 2011 08:40 PM
C2K_TB_TEC
18
Mar 31, 2009 04:56 AM
little2fast4u
Aug 2, 2008 06:46 PM
Jan 2, 2002 10:23 PM
