what do u guys do with your air intake temp. sensor?
Old Mar 4, 2003 | 06:14 AM
lilxvtecxpwr's Avatar
Default what do u guys do with your air intake temp. sensor?
its the little sensor you stick inside your intake. what do you guys do with this sensor on a turbo car? do you drill a hole in your charge pipe or do u guys just leave it out. wont i get a cel if i leave it out?
Old Mar 4, 2003 | 06:17 AM
nsxmatt's Avatar
Default Re: what do u guys do with your air intake temp. sensor? (lilxvtecxpwr)
Tie it off onto something. As long as it's plugged into the harness you'll be fine. If you drill into the charge pipe you could end up shooting it out all the time. Some people do run it in the charge pipe but i'm sure it would have to be pretty secure to stay put.
Old Mar 4, 2003 | 06:28 AM
MikeMAN's Avatar
well, i used my AEM CAI as my upper charge pipe ( don't have any clue why people don't use one as an uppercharge pipe, tons cheaper than paying for an overpriced drag piece) so i just left it. Otherwise, tie it off unless you can drill a hole and use a rubber grommet to hold it in place.
Good luck!,
mike
laxbuddy48
Aug 19, 2007 11:31 AM
boostincoupe
Jan 28, 2005 06:20 PM
buck02
Jan 22, 2004 08:39 PM
CzanSOHC
Jul 14, 2003 08:25 AM
Trac226
Apr 27, 2002 01:41 PM
