What to do for a turbo set up..
Old May 18, 2010 | 08:38 PM
GORILLARILLA21's Avatar
Default What to do for a turbo set up..
I have a b18a with about 70k miles. It has almost all the bolt ons (no manifold), but no internal upgrades. In a list, what would you guys put on in order? (as in the size if it has one, and brand) And my goal is 500hp so I want the parts to support that. Thanks in advance! And yes I have researched it, but I would like to see your guys' opinion on the parts and order to buy them.
Old May 19, 2010 | 06:17 AM
TylerB's Avatar
Default Re: What to do for a turbo set up..
Since you have researched, post your list of parts up and someone will critique it and let you know where you need to improve.
Old May 19, 2010 | 07:16 AM
DA 4 Lyfe's Avatar
I'll make it easy for ya:
Engine:
LS Vtec
CP 9:1 Pistons
Eagle Rods
Skunk 2 IM
Blox Type B Cams
Golden Eagle Cam Gears
Omni Power Springs + Retainers
ARP Headstuds
Turbo Kit:
Synapse Motorsport Ram Horn
Garrett GT3076r
Synapse Intercooler Piping
Precision 600 Intercooler
Tial 44mm Wastegate
Tial Q BOV
3in Kteller Exhaust
3in Downpipe
Transmission:
ClutchMasters Stage 5
Quife LSD Differential
Fully Rebuilt LS Tranny With OEM Gears
Fuel + Management:
Precision 880cc Injectors
Walbro 255
Neptune RTP
stock sleeves, no head work. last years setup made 506whp at 23psi. Coulda made more but maxed out the 880's.
Old May 19, 2010 | 03:08 PM
Did your engine blow? Or is it still good? Thank you! I wasn't sure if I should vtec it if I was going to turbo it. What head did you use? b16 or b18c? thanks!
Old May 19, 2010 | 03:25 PM
azandford's Avatar
you should definently get a vtec head... no matter if its boosted or not.
Old May 19, 2010 | 03:58 PM
TheZooKeeper's Avatar
The new Billet Precision turbos are doing great. I would def run one if I didnt already have a 30R
Old May 19, 2010 | 05:13 PM
DA 4 Lyfe's Avatar
+1
Old May 19, 2010 | 05:16 PM
DA 4 Lyfe's Avatar
I would deff. get a B16 head, flows alot better up top with easier power to be made. The motor did not blow, I had the block sleeved and port flow head work done in April.
Old May 19, 2010 | 06:46 PM
How long were you running it without it being sleeved? And i'll take a look at that turbo. Thanks guys!
Old May 20, 2010 | 07:01 AM
DA 4 Lyfe's Avatar
2+ years. The car did make 500+ but that was on race gas c16. I didnt run race gas too often.
Saucegiver
Oct 22, 2014 04:44 AM
DA 4 Lyfe
Sep 4, 2011 03:22 AM
95civlx
May 26, 2010 06:02 AM
bootlegcivic
Apr 28, 2008 01:47 AM
