What to do to make 350-375hp Safely?
Old May 6, 2009 | 12:25 PM
precisionsc54's Avatar
Default What to do to make 350-375hp Safely?
Car is a 94 GSR with well over 100,000 on the clock. Motors getting kinda tired and smokes pretty good upon hitting vtec. That real nice blue color Anyways I ve decided to go to the dark side and build a basic turbo GSR setup. Now my question is this. I just picked up a set of Wiseco Pistons 81.5mm 8.8:1 comp from a fellow H-T member. I know I need some rods prolly just some eagle H-Beams. What else should I do while its all apart? Someone give me the run down.
Obviously bored to 81.5mm
Micropolish the crank?
ARP head studs?
New oil pump
All new bearings
All new gaskets
As far as the head goes Im not that knowledgable
So please let me know.
Old May 6, 2009 | 12:38 PM
tegman23's Avatar
Default Re: What to do to make 350-375hp Safely?
Get the bottom end balanced...Head doesnt really have to be done, but some valve train would help make your setup more reliable....Arp headstuds or any aftermarket brank will be fine...
Obviously you have to pick a turbo setup to support your goals as well
Old May 6, 2009 | 12:46 PM
red_crx's Avatar
As far as the head in concerned; I would keep it stock and maybe add some ITR cams.
My buddy and I had the same exact setup about a year ago and he made around 370whp on his stock gsr.
setup:
inline pro stainless manifold
sc61
RC 750cc injectors
ebay intercooler
2.5" aluminum ic piping
victor x intake manifold
tial 38mm wastegate
tial bov
Old May 6, 2009 | 12:53 PM
I forgot to add that it has a skunk2 intake mani and throttle body. Should i just freshen the head up? I got a wierd t4 manifold I plan on using so I need 2 find a t4 turbo with an A/R to match my goals
Old May 6, 2009 | 02:00 PM
hbyrd8701's Avatar
like tegman23 said, get the bottomend balanced. as for the head, freshing it up and get new valve seals, aftermarket valvetrain and itr cams. also get rid of that t4 manifold and find a nice castiron, log or ramhorn manifold. a t3t4 57 trim with a 60/63 a/r is good for your goal.
Old May 6, 2009 | 02:29 PM
VtecCarHauler's Avatar
I would suggest getting an oil catch can.
Old May 6, 2009 | 03:41 PM
96 GSR-T's Avatar
Never hurts to get the crank checked and polished. Big power can be made on the stock head, but it never hurts to upgrade.... if you do I would send it out to have it checked over, have the guides checked and replaced if necessary, new valve seals, check the straightness of the deck and cut if necessary, and if you still have money to spend you could always throw a decent set of aftermarket springs/retainers in there.
Old May 6, 2009 | 03:57 PM
Schister66's Avatar
Man U FTW
A simple piston/rod combo and a 57 trim on pump gas will get you to your goals easily. Hell, a stock block with E85 and a slightly larger turbo will get you there too. Check out HybridLS-T's thread in FI...he's making 415whp currently on his stock block
Old May 6, 2009 | 04:00 PM
INLET
4"
INTAKE
2.5"
BEARING TYPE
WET FLOAT BEARINGS
OIL INLET
1/8 NPT
MAX PSI CAPACITY
35 PSI
COMPRESSOR
.70 AR
TURBINE
.68 AR
COMPRESSOR WHEEL
57.89 /72.95
TURBINE WHEEL
54.47 /83.16
FLANGE TYPE
T4 FLANGE
DOWN PIPE FLANGE TYPE
3??? V BAND
COOLING TYPE
oil cool only
You dont think this would spool up good?
Old May 6, 2009 | 04:22 PM
wkpmichael's Avatar
u got it man far as the head goes slap a skunk 2 valve train on there and you good. That should be a easy goal with a 50trim or up
Old May 7, 2009 | 05:25 AM
up
Old May 7, 2009 | 06:27 PM
anyone else
Old May 7, 2009 | 07:24 PM
Silva Bullit DC4's Avatar
Originally Posted by precisionsc54
INLET
4"
INTAKE
2.5"
BEARING TYPE
WET FLOAT BEARINGS
OIL INLET
1/8 NPT
MAX PSI CAPACITY
35 PSI
COMPRESSOR
.70 AR
TURBINE
.68 AR
COMPRESSOR WHEEL
57.89 /72.95
TURBINE WHEEL
54.47 /83.16
FLANGE TYPE
T4 FLANGE
3??? V BAND
COOLING TYPE
oil cool only
Thats a 60-1 turbo, it will reach maximum pressure later in the powerband than that 57 trim would.
Old May 7, 2009 | 08:30 PM
96 GSR-T's Avatar
That manifold is wild, what size wastegate is it flanged for? You should find a Turbo that has the same divided collector, it will help your spool out some with the T4 setup.
Old May 8, 2009 | 05:18 AM
90civichbsi's Avatar
that wastegate setup on that manifold scares me... thats alot of piping for air to get to the wastegate. Looks like it would be prone boost creep issues.
Old May 8, 2009 | 05:59 AM
so whats everyones consensus on that turbo manifold I have? I got it last yr out at SEMA as a sample product. So I figured why not use it. What A/R on a T4 should I be looking for?
Old May 8, 2009 | 06:51 AM
TheShodan's Avatar
Moderator
If its a SEMA sample, you'd better make sure that it will fit before even getting the turbo. Samples are really that. Many times they are made strictly for SEMA and may not represent the actual product's fitment. I've brought many products that were for the show, and were actually not usable on an application because of smaller issues.
Old May 8, 2009 | 07:28 AM
ya your right Im def gonna mount the manifold and take some measurements for clearances
Old May 8, 2009 | 07:31 AM
Mag00n's Avatar
350whp can be easily and reliably reached on a bone stock gsr with proper tuning and fuel system upgrades
Old May 8, 2009 | 07:51 AM
96 GSR-T's Avatar
For a street car I would definately run something under 1.00 AR Divided, anything higher will be lazier than a T4 setup already is for 375hp.
Old May 8, 2009 | 08:54 AM
ok thanks everyone. and 96 GSR-T your lights are shipping out on monday.
Old May 8, 2009 | 08:58 AM
96 GSR-T's Avatar
Awesome man thanks Cant wait to apply that JDM treatment to my car
Old May 8, 2009 | 09:17 AM
Ls_dx's Avatar
Also get a set of ngk-4554's... seems like you are on the right track....
see if you can find some ITR cams....
xSteve_Ox
Mid-Atlantic (Sales)
Jul 13, 2011 05:05 PM
madking411
Feb 13, 2011 03:19 PM
JDMDAtehbeast
Aug 11, 2008 03:17 PM
jdmcivicsi7
Nov 25, 2007 04:26 PM
spraa
Dec 29, 2003 05:57 PM
