what do I need to do to have a/c this summer?
Old Mar 18, 2006 | 01:02 AM
CrazyModGSR's Avatar
Default what do I need to do to have a/c this summer?
I have never had working a/c since I bought my turbo teg 2 years ago. Been charged. A couple pics below. I am getting new headers (any recommendations?) because they are rusted to ****. I know there are issues with the size of the downpipe and the a/c compressor. Don't I need a lovefab manifold if I want a 3" downpipe and retain a/c? I will better look at it tomorrow to see what needs to be done. I'm just sick of sweating my *** off, especially being a summer only car.
Old Mar 18, 2006 | 10:06 AM
Default Re: what do I need to do to have a/c this summer? (CrazyModGSR)
bump. i know this has been covered many times before, but if someone could give me a quick reply I would appreciate it
Old Mar 18, 2006 | 02:23 PM
siblueg's Avatar
your getting new what? you car has only one (header)if thats what you mean. and there are plenty of manifolds and 3"down pipes out their that are a/c friendly.
Old Mar 18, 2006 | 03:04 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
wtf are you trying to say?
Old Mar 18, 2006 | 03:10 PM
chubz0r's Avatar
Default Re: what do I need to do to have a/c this summer? (CALM_AS_A_BOMB)
Well if your a/c compressor is still in, which im pretty sure it is, i think you will just need to install the a/c condensor fan. i believe you will need some sort of slimline fan in order to fit between the manifold and radiator.
so pretty much, install the fan (its only 1 connector with 2 wires, you just cut off and solder the correct wires together from the car to slim fan)
let us know how it goes. good luck.
Old Mar 18, 2006 | 03:28 PM
Default Re: what do I need to do to have a/c this summer? (chubz0r)
yes, I believe this was the issue, was that the manifold and/or turbo was too close to the fan so I guess I'll need a slimline fan then. also, anyone have any direct links for a fairly lower cost exhaust manifold that I can use with the 3" downpipe and retain a/c, but won't require much modification or relocation of the existing setup. ie, something that should pretty easily bolt right in. I don't have a shitload of mechanical experience, only car stereo experience.
Old Mar 18, 2006 | 03:30 PM
btw, I am replacing my injectors, as they are still stock and old. wondering what I should get. about 7 psi of boost right now, would like to get injectors that would allow me to deliver enough fuel for up to 10 psi later on maybe. what flowrate should I look for?
Old Mar 19, 2006 | 01:10 PM
?? injector size??
Old Mar 19, 2006 | 01:36 PM
StolenTeg's Avatar
550cc or 750cc saturated rc injector
Old Mar 19, 2006 | 01:48 PM
jfoster's Avatar
Default Re: what do I need to do to have a/c this summer? (StolenTeg)
BLOX manifolds are cheap and you can get 3" AC compliant DPs for them. I am running a BLOX mani with AC in my LS
Old Mar 19, 2006 | 03:17 PM
VI Boost's Avatar
Default Re: what do I need to do to have a/c this summer? (jfoster)
spoolin performance log manifold w/ 3" downpipe
rndmheroxx
Welding / Fabrication
10
Apr 14, 2011 03:37 PM
projectTeG
Oct 18, 2009 07:52 AM
lilo_goki
Jul 21, 2008 10:54 AM
trustnoone5656
Aug 19, 2007 08:39 AM
TurboT
Apr 1, 2002 11:04 AM
