What is the difference between Dry and wet NOS?
Old Jul 16, 2002 | 05:38 PM
crxracer91''s Avatar
Default What is the difference between Dry and wet NOS?
I don't know if there is a diffence in HP between wet and dry NOS. I also don't know which one to put in my car (1990 Crx) help me out
Old Jul 16, 2002 | 05:59 PM
Booger's_Rex's Avatar
Default Re: What is the difference between Dry and wet NOS? (crxracer91')
wet usually goes directly into the intake manifold and dry is usually into throttle body or intake. i would go with dry myself unless you got a built engine. hondas seem to like dry better
Old Jul 16, 2002 | 06:08 PM
714phil's Avatar
Default Re: What is the difference between Dry and wet NOS? (Booger's_Rex)
uh i dont think that is correct......
dry- nitrous only
wet- nitrous AND fuel
Old Jul 16, 2002 | 06:15 PM
Hcivic88's Avatar
Default Re: What is the difference between Dry and wet NOS? (STD ONEpointSIX)
dry- nitrous only
the dry goes into the intake, and the wet goes into the fuel
Old Jul 16, 2002 | 08:19 PM
DOHCtorJT's Avatar
Default Re: What is the difference between Dry and wet NOS? (Hcivic88)
Dry nitrous means that only nitrous is injected into the system.
Wet nitrous means that nitrous and fuel are injected into the system.
Dry uses one solenoid for nitrous, wet uses one for nitrous and one for fuel.
Old Jul 16, 2002 | 09:08 PM
reXem's Avatar
Default Re: What is the difference between Dry and wet NOS? (DOHCtorJT)
Then wouldn't wet be better? since it compenstates for the extra air with extra fuel and therefore helping stop running lean?
Old Jul 16, 2002 | 09:47 PM
island_son's Avatar
Default Re: What is the difference between Dry and wet NOS? (reXem)
A wet system uses both NOS and fuel. Depending on the HP shot you want to ensure that your motor is in perfect working condition. NOS doesn't care if your motor is brand new or 10 years old it will destroy your motor if you don't respect it.
In my opinion a wet system is better than dry.
Old Jul 17, 2002 | 08:19 AM
Muckman's Avatar
Moderator in Chief
How does a NOS Plate system fit in this picture? Is that a wet or dry? What is a plate system anyways? heh
Old Jul 17, 2002 | 10:36 AM
bruthaboost's Avatar
Default Re: What is the difference between Dry and wet NOS? (Muckman)
Plates (v8 style) sit between the intake manifold and the carberator (sp?) where they spray into the intake.
go here:
http://www.holley.com/HiOctn/ProdLin...S/catalog.html
Old Jul 21, 2002 | 07:09 PM
Muckman's Avatar
Moderator in Chief
Default Re: What is the difference between Dry and wet NOS? (bruthaboost)
Arent there plate systems for our motors?
Wombats6thgen
Jul 1, 2004 04:53 AM
Reddog
Dec 15, 2003 08:37 PM
bluedelsol
Mar 6, 2003 06:35 AM
civicmark
Jul 7, 2002 08:20 PM
