what could it be!!!
Old Nov 19, 2003 | 01:41 PM
Spoonvtec's Avatar
Default what could it be!!!
I was driving my car and I noticed it stutter when I step on the gas, like its choking, what it could be, I checked my oil, and its fine, fuel there is plenty of it, it was doing it from first through fifth gear. What could it be?
Old Nov 19, 2003 | 01:43 PM
redboost10's Avatar
Default Re: what could it be!!! (Spoonvtec)
maybe a little too rich? could be
Old Nov 19, 2003 | 01:49 PM
Hoosier Daddy's Avatar
Coudl be detonation. Watch out, what is your setup?
Old Nov 19, 2003 | 02:02 PM
Spoonvtec's Avatar
well the fuel set up its being the same. i haven't touched anything, all of the sudden it stared doing it.
Old Nov 19, 2003 | 02:26 PM
boosted_dc2's Avatar
Default Re: (Spoonvtec)
we need more info on your setup. what kind of fuel man. are you running???
Landon
Old Nov 19, 2003 | 02:34 PM
Spoonvtec's Avatar
Default Re: (boosted_dc2)
well its a lsvtec turbo with the following:
B18b block sleeved golden eagle
Je pistons 9:1 compression
Eagle rods
JDM Type r head
Port and polish stage 3
Titanium reatainers
Stainless steel valves
Civic type r exhaust cam
Integra type r intake cam
Vortech fuel rail
Spoon fuel regulator
Jdm Dsm 450cc injectors
JG Eldebrock Intake manifold
BBK 70mm throttle body
T3/T4OE Neutec Hybrid turbonetics turbo
3 inch down pipe
3 inch exhaust
External wastegate with dump pipe
15 core front mount intercooler
Pulleys
Cam gears
Type s bov or ssq if desired
Chrome piping
JDM Type r valve cover
10.5 mm spark plug wires
New radiator
New igniter
New coil
Vortech fmu
Jdm p28 ecu chipped with lsvtec program
Jdm type r tranny
Exeddy stage 4 clutch with heavy duty pressure palte
Assco aluminum flywheel 8lbs
JDM type r shift linkage
could it be fault spark plugs?
Old Nov 19, 2003 | 02:38 PM
boostedbastard's Avatar
What is your ratio on the fmu?
Old Nov 19, 2003 | 02:42 PM
99B16Si's Avatar
Default Re: (boostedbastard)
the FMU may be broken, thats my guess. try taking it out and driving out of boost
Old Nov 19, 2003 | 02:51 PM
Default Re: (99B16Si)
Thats what I was getting at. Sometimes the plates in a fmu will form a small pin hole.
Old Nov 19, 2003 | 02:57 PM
Spoonvtec's Avatar
how can you fix the problem with the fmu.yes i was running the car without getting in on boost and was still doing it.my fmu is is 12:1
Old Nov 19, 2003 | 03:37 PM
PrecisionH23a's Avatar
Which plugs are you running again? Did the motor all of a sudden start running like this?
Old Nov 19, 2003 | 03:40 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoonvtec &raquo;</TD></TR><TR><TD CLASS="quote">well its a lsvtec turbo with the following:
Eagle rods
JDM Type r head
Titanium reatainers
Vortech fuel rail
3 inch down pipe
3 inch exhaust
Pulleys
Cam gears
Chrome piping
New radiator
New igniter
New coil
Vortech fmu
Jdm type r tranny
could it be fault spark plugs?</TD></TR></TABLE>
My question is with all this money in the engine how come you dont have some good fuel management?? At least do the hack over the FMU. That would probably make your car run alot better. Check your ignotion components as well.
Old Nov 19, 2003 | 05:19 PM
Spoonvtec's Avatar
well i looked and i have some bosh platinum spark plugs, i know they are not the best but i think that should be the problem too. what do you guys think?
streetracer6rpt
Jun 20, 2007 06:41 AM
streetracer6rpt
Jun 18, 2007 07:12 PM
yee SERIOUS
Jun 14, 2006 07:20 AM
AllMotorGSR94
Jan 26, 2006 07:53 PM
