What is the correct breakin procedure for a rebuilt engine?
Upon start up, set a high idle of 1500-2000rpm. You can do this by introducing a vaccum leak. I let it idle at that speed for 20 minutes. During this time, it's a great time to find any leaks you might have missed.
After that, I prefer to change the oil and filter. A magnetic drain plug is really help ful in this situation as well.
After you set the timing, bleed the coolant system, and do any and all other fluid type checks, go out and drive it easy for the first 100 miles, gradually increasing rpm, load, and throttle as you go. After that, I drive it up to a total of 600 miles of normal daily driving before commencing normal punishment
Be sure to change the oil and filter again before doing so. This is just my way of doing it, works fine for me.
Greg
Drive it the way it was built for. IE: You build a race engine, do a couple pulls on the highway in 3rd or 4th from 2000 to 4000, then a couple from 2000 to 6000, then a few more to redline. If its boosted, do it in series. IE: all three with low boost, then all three with medium boost, then all three with high boost. Never fails. Done this on several engines and they are still running as daily cars for the past couple years.
A slow easy break in "will work." But thats boring and if your engine is built right, it won't matter. The only thing you are trying to do here is get the rings to seat. Anything else should have been taken care of in the build. Unless of course, you have a crappy clutch that needs a million mile break in.
that's pretty much what we did. Built and threw the thing on the dyno. Haven't had any problems yet after 2 months and 4000 miles.
I let it idle high for about 20 minutes, then go drive it softly for 20 miles. Come back, oil and filter change, then take it back out. Drive 250 miles, adding throttle and rpm as you go...letting the rpm's go up and then deaccelerate and let them come down. Don't be too easy on the motor because you need load to get the rings to seal. After that you can just rape it...Personally I dont even wait those 250 miles. I idle for 20, drive around easy for 10 minutes then just start getting on it..you can feel it get faster each time you step on it because the rings are sealing as you drive..
Is the only purpose sealing the rings when breaking in motors? Any other goals?
I dont know this is what a reputable engine builder in my area told me, he said if its a daily driven vtec car, ie, gsr, lude whatever, it needs 20 minutes to warm up, at a higher rpm, forced vacum leak, then easy driving for the first 10 minutes or so, then moderate driveing next 10 minutes, then hard but not to redline, he told me never over 6k rpm in the first 100 miles, then you change the oil and coolant, then assume regular driving, but the weird thing he told me was to drive the **** around for the next 5000 miles under 6k rpms, while letting the motor warm up and cool down every time you drive it, i dont know he said he never had a problem with any customers **** that did that but if they boosted hardcore on it under 5k then he had problems.....tell me what you think
IE: 3k~first 100-150, 3500~250, 4k~350-400, 5k~etc...everybody has thier own routine though
Dekorum
44
Oct 14, 2018 06:53 AM
JCCOOL43
Oct 2, 2003 12:08 AM
