Boost Creeping?
Old Apr 18, 2005 | 10:31 AM
turtle-eg's Avatar
Default Boost Creeping?
Wondering if any of you have this problem....
Whenever I use a boost controller(turboxs dual), I would have boost creeping 1-3psi and then dropping back to where it's set at. For example, if I set it to 23psi, it would goto 25psi and then drop back down to 23. I thought it was the boost controller, changed it out to a single stage and does the same thing.
I have changed the manifold, boost controller, turbo, wastegate(currently using a tial 38mm with red spring), downpipe 3" and it still creeps 1.2psi.
Old Apr 18, 2005 | 10:33 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Boost Creeping? (turtle-eg)
what manifold?
Old Apr 18, 2005 | 12:32 PM
turtle-eg's Avatar
Default Re: Boost Creeping? (wantboost)
It's a crfab ramhorn manifold found in the sponsored section here. I was using a ebay manifold before, same problem.
Old Apr 18, 2005 | 02:35 PM
wantboost's Avatar
Who is Mr Robot?
its the mani design, not that its bad, its just to efficient..
the exhaust gases have problems flowing 90* to the direction they are traveling
eglsvtec23
May 1, 2007 11:15 AM
ALL IMPORT
Aug 18, 2006 08:05 PM
miller
Aug 12, 2004 01:53 AM
KekeK-18
May 22, 2002 05:10 PM
