What can I run?
Old May 6, 2003 | 09:18 AM
ELSpool's Avatar
Default What can I run?
I'm just finishing a D16Y8 turbo project in an Acura 1.6 EL
Stock internals
T3/To4e .48 exhaust, .50 compressor internal gate
Talon 450cc injectors
AFC Hack
Tech Edge Wideband tuned to 11.5 a/f ratio (safe) on 94 octane
2 heat range colder plugs
2.5 inch exhaust, DP, and cat
Water to Air IC
Thats about it, I want to run 9 psi, is that pushing it?
Comments concerns recommendations please!
Old May 6, 2003 | 09:29 AM
madman604's Avatar
Default Re: What can I run? (HiRolla)
low 14's high 13's
Old May 6, 2003 | 09:36 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
Depends on the driver and the weather....Are you going to getting slicks? If so in tip top conditions you should be getting about mid 13's.....
Old May 6, 2003 | 09:46 AM
ELSpool's Avatar
Not times, I'm asking am I pushing the engine to hard a 9 psi??
Old May 6, 2003 | 10:04 AM
ELSpool's Avatar
Anyone else?
Old May 6, 2003 | 10:21 AM
Q-Tip's Avatar
Default Re: (HiRolla)
11.5? i thought my low 12's was on the safe side
Old May 6, 2003 | 11:35 AM
gitwidit's Avatar
Default Re: (Q-Tip)
9 lbs. would be on the high side but you can do it (assuming factory bottom), I'd probably start at 7 though.
edit: just noticed your going to tune, hell yeah, run 9!
cpl rampage
Jul 11, 2008 03:39 AM
bodea_florian
Sep 4, 2004 03:34 PM
Integgedout
Aug 14, 2004 12:21 PM
mrod006
Nov 5, 2002 05:42 AM
