What cams would you recommend?
Old Aug 22, 2007 | 06:04 PM
EM-One's Avatar
Default What cams would you recommend?
Hey guys, I'm boring out my b16a2 to 81.5 and putting 9:1 pistons and forged rods. I have a Greddy 18g turbo & log mani w/3 inch DP and exhaust, and tuned on Hondata I plan on running 9-10 psi on low boost and 15-16 psi on high boost.
I want to maximize my setup by adding some performance cams, titanium valve springs, and retainers. What cams do you recommend for a daily street driven set up like this. I've been hearing Blox B's and Skunk 2 Stage 2. Thanks for the help!
Old Aug 22, 2007 | 07:00 PM
EM-One's Avatar
Default Re: What cams would you recommend? (EM-One)
Anyone?? Or should I just go w/ ITR cams??
Old Aug 22, 2007 | 07:16 PM
A.E Motoring's Avatar
itr/gsr will be just fine
Old Aug 22, 2007 | 07:17 PM
bigbadboy's Avatar
for the money just get some skunk stage 1 or 2's
Old Aug 22, 2007 | 10:58 PM
Ls1 FD3s's Avatar
Default Re: (bigbadboy)
00 CTR is what i live by...
Old Aug 23, 2007 | 07:25 PM
EM-One's Avatar
Default Re: (Ls1 FD3s)
Anyone else?? I may go with ITR's, but I would like to redline a little over 9k, and I want a cam that can give me the best hp gain. Should I do ITR and titianium valve springs and retainers, or should I go with an aftermarket stage 2 cam like Skunk2?
Thanks for the help.
Old Aug 23, 2007 | 08:33 PM
bigbadboy's Avatar
look up the comparision that Tony1 did between the ITRs and the skunk pro 1's. pro 1's did way better than the ITR's
Old Aug 24, 2007 | 08:20 AM
project dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy &raquo;</TD></TR><TR><TD CLASS="quote">look up the comparision that Tony1 did between the ITRs and the skunk pro 1's. pro 1's did way better than the ITR's</TD></TR></TABLE>
keep in mind, the power the car was already putting out warranted much higher cam profiles and more engine flow.
on his 18G setup i'd go with some blox A's because its gonna be a 350 WHP MAX setup
Old Aug 24, 2007 | 12:28 PM
bigbadboy's Avatar
yea true i forgot he was using a log mani. but since he's only staying at that power level and not going higher its better just to keep the stock cams or get some cheap GSR's and just spend the rest of the money on a good tuner
carlossolorzano
May 18, 2012 04:38 PM
cleanep3
Jun 15, 2010 06:12 AM
ITR092
Dec 21, 2005 06:00 AM
ITR #1202
Jan 9, 2004 11:29 AM
2k1 GSR
Jun 18, 2002 07:54 PM
