What boost is safe to run daily
Ok my think is this, I was researching on the K20 swap and I've seen numbers at 6.5psi pushin about 275whp and that got me thinking right there, maybe I should get the K series, but at first I had the B18c and it was fully built, so is it possible to get 275whp on 6-9 psi?
Eagle Rods
GE Sleeves or Stock
Stock GSR head and cams
CP Pistons 9.1 or 9.5
Stock Intake manifold
FMAX Stage 2 Turbo
3'' Apexi N1 Exhaust
Hondata S200b or Stage 3.
500 or 700 RC Peak and Hold Injectors
60-1 t3/t4e hybrid with a stage 3 turbine wheel
I've searched and no results but if anyones has pushed 275whp on a low number psi then tell me ur setup.
Modified by Austinbionic316 at 6:44 AM 3/17/2004
Eagle Rods
GE Sleeves or Stock
FMAX Stage 2 Turbo
It doesn't matter how much psi you run daily, it's the amount of horsepower that puts wear on your engine. With your buildup 275whp should be fine with a good tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">It doesn't matter how much psi you run daily, it's the amount of horsepower that puts wear on your engine. With your buildup 275whp should be fine with a good tune.</TD></TR></TABLE>
but my thing is this... once I have the B18c motor built and that extra 100whp from the turbo kit is added Im lookin at 285whp at 7-9psi correct? cause Im tryin to be the human dyno here and I wanna make sure im correct, cause I was reading somethin off turbo-kits.com its a 125whp gain once the kit is installed.
The FMAX Stage 2
The FMAX Stage 2
It's possible that you will make that power at 6-9psi, but everyone's setup is different. It's very hard to be a human dyno. You need a real one.
lol yeah I know...but man that K series swap would be so sweet tho but for the header, mounts, and axles is like $1335.00 plus the cost of the swap...aye thats mad cash.
B18CXr
Oct 18, 2005 06:16 AM
