what attachment is this?
Old Dec 9, 2007 | 09:36 AM
hyabusa hunter's Avatar
Default what attachment is this?
welded to the end of the compressor outlet?
Old Dec 9, 2007 | 09:38 AM
SpoolnG2's Avatar
Default Re: what attachment is this? (hyabusa hunter)
Its a V-band fitting
Old Dec 9, 2007 | 09:40 AM
Default Re: what attachment is this? (SpoolnG2)
really? with a O ring?
Old Dec 9, 2007 | 09:46 AM
CoreyR's Avatar
wiggins clamp fitting....
Old Dec 9, 2007 | 10:53 AM
tepid1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">Its a V-band fitting</TD></TR></TABLE>
Nope... It's 100% a wiggins/hydraflow ferrule.
Old Dec 9, 2007 | 10:55 AM
boosstboy's Avatar
Default Re: what attachment is this? (tepid1)
no, it's baller
where can you get them from? and the clamps?
Old Dec 9, 2007 | 11:00 AM
boosstboy's Avatar
burns ss has them but they are pricey.
http://www.burnsstainless.com/....html
Old Dec 9, 2007 | 11:01 AM
tepid1's Avatar
Burnsstainless.com
or search wiggins here on H-T
Phil from spoolin performance has some for sale right now. You just need to know what size it is.
Old Dec 9, 2007 | 11:08 AM
the turbo is a GT42R so im thinking 3", please correct me if im wrong
Old Dec 9, 2007 | 11:14 AM
tepid1's Avatar
It's either 2.5 or 3"
Old Dec 9, 2007 | 11:26 AM
thanks guys, much appreciated
Old Dec 9, 2007 | 01:40 PM
RCautoworks's Avatar
Default Re: what attachment is this? (boosstboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosstboy &raquo;</TD></TR><TR><TD CLASS="quote">no, it's baller </TD></TR></TABLE>
Thats how we order them, I need 10 of the baller clamps in purple please, thanks.
Old Dec 9, 2007 | 01:48 PM
boosstboy's Avatar
Default Re: what attachment is this? (RCautoworks)
haha , i wish i had the money for those, oh well t-bolts for me.
Old Dec 9, 2007 | 02:02 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
http://www.hondamarketplace.co...35097
Old Dec 9, 2007 | 02:09 PM
SpoolnG2's Avatar
Default Re: (tannerLSt)
whats the difference between a wiggins clamp and a v-band clamp? Same concept right? Just different names?
Old Dec 9, 2007 | 02:23 PM
tokesGTR's Avatar
Default Re: (rota92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, however the Wiggens uses O-rings instead of just mating two flanges together.
Use them on some test rigs at work, my new setup will use these for sure. Luckily there are only 2 </TD></TR></TABLE>
Not qute the same, you can't have much/any movement on a V-band or it will lose seal, whereas the Wiggens clamps will allow some movement/flex of the joint without bursting or losing pressure.
Old Dec 9, 2007 | 03:00 PM
Garage 808 Hatch's Avatar
i cant remember where i got them, but i bought aluminum, o-ringed v-bands for less that $50 each. 2 1/2" and 3" for my charge piping. 1 piece piping FTW
Old Dec 9, 2007 | 03:13 PM
they are made by Vibrant, here they are
50ish for 2 1/2
57 for 3"
74 for 4"
http://www.midwestspeedsupply.....html
Old Dec 9, 2007 | 03:15 PM
Default Re: (Garage 808 Hatch)
there was also a place online that would send you a AL/SS setup for doing exhausts, not o-ringed for obvious reasons though
Old Dec 9, 2007 | 03:19 PM
on the turbo
on the TB
tony1's Avatar
Wiggins clamps allow 10-15 degrees of movement when fully assembled. A wiggins on each side of a one piece intercooler pipe is fine, a v band on each side of a 1 pc pipe is not fine because if the motor moves at all something is going to crack.
Old Dec 9, 2007 | 03:38 PM
but the motor, and both manifolds will move together. as they are bolted together
Old Dec 9, 2007 | 03:52 PM
in that way yes, thought he was replying to my pics, in which it sits on a block, to allow movement.
but ya, on a large system with parts hard mounted, could be bad.
hey tony, what about a flex pipe
Old Dec 9, 2007 | 03:55 PM
tepid1's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Wiggins clamps allow 10-15 degrees of movement when fully assembled. A wiggins on each side of a one piece intercooler pipe is fine, a v band on each side of a 1 pc pipe is not fine because if the motor moves at all something is going to crack.</TD></TR></TABLE>
I believe it's + - 3.5 degrees actually. lol
