what all is needed to build a boosted b20b vtec??
Old Jan 16, 2010 | 01:01 PM
DC2fab's Avatar
Default what all is needed to build a boosted b20b vtec??
im currently building a b20b vtec turbo to swap in my integra.. im running the block with a b18c and gsr tranny. i was just wondering what all is need to do the conversion. i know alot of the b20b components are similiar to the b18c like water pump, oil pump, girdle, oil pan etc. and i know the cranks are different which i already have an ls eagle knife edged crank. but what else goes into this build. what oil lines have to be switched from the head to block etc. please give me what you got. be specific. thanks
Old Jan 16, 2010 | 01:11 PM
zedron's Avatar
Default Re: what all is needed to build a boosted b20b vtec??
Oil pump and girdle are not the same on a B18c1 and a B20.
Ill tell you my setup I had:
B20B block
LS Crank
Eagle LS Rods (but you can use stock LS ones too and buy ARP rod bolts for them)
Wiseco pistons but you can use the OEM LS ones to lower comp if you plan not to boost too much.
GSR oil pump
LS windage tray
LS oil pickup
ITR/GSR (P72) water pump (dont use and LS. At higher RPMS it will cavitate instead of moving water)
Tapped ls oil pan (i eventually changed this to a moroso)
B16 head (tapped for Vtec)
Type R intake manifold
ITR Cams
ITR Valvetrain
Type R TB
Dowel Pins
LS IACV
LS/Vtec sandwich plate (google it and you will see what it is)
Oil line to go from sandwich plate to the new tapped fitting on head
oil line to go from sandwich plate to turbo
Turbo manifold
Turbo
Turbo drain line
intercooler
charge piping
BOV
Wastegate
hmmm, might be missing stuff
Old Jan 16, 2010 | 01:24 PM
DC2fab's Avatar
sounds like a nice setup man.. ha yea a buddy of mine told me just about the exact same thing today about sandwich plate today and he works for a crazy motor shop and builds masty hondas so i can tell you know what your doing lol. ok so the oil pump and girdle are different. is that all that you know of or is there other stuff?? sorry im just a little confused on ls/vtecs. im only 16 but i been around motors my whole life and built them. just never an ls vtec ha
Old Jan 16, 2010 | 01:37 PM
zedron's Avatar
I meant to say oil pump, windage tray and oil pickup are different. B20s dont have block girdles.
Everything in a B20 is different than a B18C1
Use what I posted and have fun when its done.
b20quang
Apr 23, 2008 11:06 PM
boostincoupe
Feb 29, 2008 03:52 PM
1995sir
Jul 10, 2006 10:19 PM
steelies
Jul 29, 2005 03:24 AM
RC000E
Nov 29, 2004 10:35 AM
