Welding a sump to the stock tank?
What are you guys doing to prevent rust from building up inside the tank after you weld a sump? Wont the high heat from welding burn the coating on the inside of the tank?
Adriano
Adriano
Re: Welding a sump to the stock tank? (N20civicB18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 »</TD></TR><TR><TD CLASS="quote">gas should keep it from rusting if you keep it full</TD></TR></TABLE>
Yup.
Yup.
Re: Welding a sump to the stock tank? (siblues)
whats being used to clean the tank of any remaining gas or fumes, in order to not blow yourself up when welding on a sump onto the tank?
Re: Welding a sump to the stock tank? (MeanGreenMachine)
free easy way, route an exhaust hose from, say your buddy's vehicle, and pump exhaust gas into the tank. that works.
Re: Welding a sump to the stock tank? (Adriano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine »</TD></TR><TR><TD CLASS="quote">whats being used to clean the tank of any remaining gas or fumes, in order to not blow yourself up when welding on a sump onto the tank?</TD></TR></TABLE>
bump i liked to know also
Re: Welding a sump to the stock tank? (nonvtecallmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecallmotor »</TD></TR><TR><TD CLASS="quote">I ran water in it and drained, then welded.</TD></TR></TABLE>me too filled with soap and water and let it sit for a couple days,welded and cleaned.
Re: Welding a sump to the stock tank? (swapit)
Gasoline has a small percentage of lubrication oils for the pump/injectors/etc. That and a full tank (keeps oxygen from touching the metal) will keep it from rusting. The problem is that after 30-50 years you may have some issues from the ethanol in fuel now (its oxygenated). But that's still WAYS away...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swapit »</TD></TR><TR><TD CLASS="quote">me too filled with soap and water and let it sit for a couple days,welded and cleaned.</TD></TR></TABLE>
awesome thanks alot will do that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swapit »</TD></TR><TR><TD CLASS="quote">me too filled with soap and water and let it sit for a couple days,welded and cleaned.</TD></TR></TABLE>I cant take all that waiting. lol I welded it right away.
lv6l
10-16-2005 10:17 AM
