Weld it or scrap it?
Old Nov 24, 2011 | 06:48 PM
Squigglez's Avatar
Default Weld it or scrap it?
My car kept leaking coolant, the engine is a freshly built rod/piston setup 0 miles on it not sure if I should weld it and call it good or scrap the block and have another one machined. Opinions?
Old Nov 24, 2011 | 07:51 PM
Fnix's Avatar
Default Re: Weld it or scrap it?
Get a new one since you already have internals and save money down the road later
Old Nov 24, 2011 | 08:00 PM
Squigglez's Avatar
yeah the only reason I am tempted to weld it is the fact that the rotating assembly pulled out of the engine had no signs of any kind of side loadings its as if the crack came from a wreck or something. thrust bearings were fine, mains/rods were fine, piston skirts had no signs of abnormal wear or anything.
Old Nov 24, 2011 | 08:41 PM
viper_boy403's Avatar
Why not just weld it? what do you have to lose from trying?
Old Nov 25, 2011 | 08:04 AM
Schister66's Avatar
Man U FTW
My thoughts exactly
I wouldnt recommend a home remedy unless you know what you're doing. To weld the crack properly, you'll need to bevel the edges of it and then fill the gap. You could ask for advice in the Welding/Fabrication forum OR i can move the thread for you.
Old Nov 25, 2011 | 08:19 AM
Fnix's Avatar
Wouldnt it cause catastrophic engine damage later on if it failed? What kind of block is it OP?
Old Nov 25, 2011 | 12:05 PM
jdm_2.2eg's Avatar
Take it to a machine shop they can weld it for you and test it make sure its not gonna fail...atleast right away
Old Nov 25, 2011 | 04:02 PM
Schister66's Avatar
Man U FTW
Where is this crack at? Can you take a larger, zoomed out picture and highlight the crack..?
Old Nov 25, 2011 | 04:36 PM
siblues's Avatar
Schister asked the perfect question it really depends on where the crack is situated.Most likely the motor will have to be dissasembled anyway to prep both sides of the crack for welding.It might be easier to just get another block.The weld will also have to be checked on the inside to make sure it has good penetration and that there is nothing that can break off causing internal damage later.
Old Nov 25, 2011 | 06:36 PM
EG1834's Avatar
Is that at the bottom of a head bolt boss?
Old Nov 26, 2011 | 08:19 AM
Squigglez's Avatar
it is, I think the old owner tightened a head bolt down with fluid in the hole, it's a Z6 block. After talking with a few machine shops local as well as a few fab guys I know they all seem to believe it can be done without removing the cylinder head, the crack only leaks under ~20 psi of coolant system pressure which I know is over what they run. I am going to go ahead and try welding it but will probably throw another block in the machine shop at the same time to have it ready just in case something goes wrong with this.
the crack is settled along the top ridge that you can see in this picture that is parallel with the two upper rear main seal bolts. I was told to run a few gallons of water through the block with the pressure tester to clean out any traces of coolant and then it could be welded. Thanks for all the replies.
celliott92
Oct 22, 2014 04:45 AM
wm5holla
Jul 28, 2003 02:06 PM
xXsarcasmXx
Feb 28, 2002 08:42 PM
