weird problem going on, need some input
Old Sep 19, 2007 | 04:34 PM
1baddturbosi's Avatar
Default weird problem going on, need some input
when my car is on accessory, i noticed a vibration & a loud noise coming from the fuse-box under the hood. I felt my cooling fan relay & it was vibrating & making noise.
I have a perma-cool radiator fan.
whats going on?????
Old Sep 19, 2007 | 07:49 PM
turboaap's Avatar
Default Re: weird problem going on, need some input (1baddturbosi)
ether the relay is bad or going bad or your batt voltage is low with the car off . or theres a bad ground.check the ground first. change the relay with a good one (new) and see how it is if the problem is still there. put a meter on the batt with the key in acc if its low sounds like a new batt is needed. hope this will help
Old Sep 20, 2007 | 04:02 AM
Default Re: weird problem going on, need some input (turboaap)
i forgot to add that about 2 months ago i had to replace my cooling relay. there was a hole burnt into the side of the relay.
Old Sep 20, 2007 | 08:40 AM
rorik's Avatar
I doubt your fan is overloading the relay, unless you have a sporadic short somewhere in the fan wiring. I don't see how a bad battery could cause a relay problem. If the trigger signal to the relay is bad though, ie, not a steady voltage, the relay could be cycling on and off very quickly over and over, creating a little arc between the contacts that is will ultimately destroy the relay. Once the contacts start to go bad, they create resistance, wich creates heat, even if it is steadily on.
Old Oct 3, 2007 | 08:38 PM
turboaap's Avatar
how did you makeout with the fan problem?
Old Oct 3, 2007 | 08:53 PM
gunslinger's Avatar
From: Where thieves get shot in the face,, texas, usa
I smell FIRE!!!!
hmtcrxsir
16
Apr 9, 2017 11:13 PM
ForceFedEg
Mar 14, 2007 12:29 PM
crxsir07
Jan 23, 2006 04:00 PM
DeadLock23
Sep 21, 2004 12:32 PM
Feuerraeder
Audio / Security / Video
Mar 15, 2002 06:43 AM
