ways to quiet down bosch inline fuel pump!
Old Dec 25, 2001 | 10:09 PM
DIRep972's Avatar
Smarter than you
Default ways to quiet down bosch inline fuel pump!
I was thinking about spraying it with road kill and then wrapping it in dyno mat.. then mounting it under the car.. anyone think this will work? anyone got any ideas
[Modified by DIRep972, 7:09 AM 12/26/2001]
Old Dec 25, 2001 | 10:13 PM
sloaccord's Avatar
New User
Default Re: ways to quiet down bosch inline fuel pump! (DIRep972)
shouldnt it be uncovered for cooling purposes?
Old Dec 25, 2001 | 10:14 PM
DIRep972's Avatar
Smarter than you
Default Re: ways to quiet down bosch inline fuel pump! (sloaccord)
yes and all reasons I "should not" do this would be helpful
Arturbo's Avatar
Better than steak
25 Year Member
Why would you want it cool?
art
Old Dec 25, 2001 | 10:23 PM
DIRep972's Avatar
Smarter than you
Default Re: ways to quiet down bosch inline fuel pump! (RealTegGirl)
just get a hondata and be done with it.
i could buy hondata but i couldnt afford the injectors, intank fuel pump or dyno time to go with it..
[Modified by DIRep972, 7:25 AM 12/26/2001]
Old Dec 25, 2001 | 11:34 PM
LsTurbo91's Avatar
You could purchase one of those 2" Rubber Pipe connectors from home depot for only $5, here's a pic from TOO's website: it fits snugly on the pump
[Modified by LsTurbo91, 12:34 AM 12/26/2001]
Old Dec 26, 2001 | 02:51 AM
dbman96's Avatar
New User
Default Re: ways to quiet down bosch inline fuel pump! (LsTurbo91)
I found that rubber connector wasn't thick enough to quiet it down much, but at Orchard Hardware I found some 1/4" thick neoprene rubber sheet which I cut to wrap and zip-tie around the fuel pump and with that on I couldn't even hear the thing.
Old Dec 26, 2001 | 05:45 AM
1's Avatar
Default Re: ways to quiet down bosch inline fuel pump! (dbman96)
I have a 92 GSR and I mounted mine under the plastic shield right next to the gas tank. I can barely tell that it is there and plus it is hidden and protected.
Old Dec 26, 2001 | 05:56 AM
AlphaKennyWun's Avatar
Default Re: ways to quiet down bosch inline fuel pump! (1)
I found it quiet inside the engine compartment....but im not sure moving it was one of your options. I also think that if you dynomat underneath the rear seats it might muffle the sound a bit. I wouldnt wrap the pump with anything though....The pump prob needs to cool.
Old Dec 26, 2001 | 06:19 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: ways to quiet down bosch inline fuel pump! (SO3Burner)
Can somebody answer why it needs to be cooled?
Old Dec 26, 2001 | 08:19 AM
VTECPWR's Avatar
Correct me if I am wrong, but SO3Burner talks about mounting the pump in the engine compartment. Isn't this bad? Electric fuel pumps push better than pull, so aren't you asking for problems mounting it in the enging compartment?
Old Dec 26, 2001 | 08:54 AM
LudeBehavior's Avatar
New User
Default Re: ways to quiet down bosch inline fuel pump! (VTECPWR)
Come on ya know ya wanna sound like a bumble bee on crack.
we wrapped it with some dynomat (left over) and it still sounds loud.
Old Dec 26, 2001 | 10:38 AM
SiR Kid's Avatar
New User
Default Re: ways to quiet down bosch inline fuel pump! (LudeBehavior)
I'd think that the FUEL running through the pump would cool it MUCH more than the air blowing past it...
Just a thought.
Old Dec 26, 2001 | 11:51 AM
quick108's Avatar
Default Re: ways to quiet down bosch inline fuel pump! (SiR Kid)
I kept my intank fuel pump hooked up and bought an MSD activation switch so my inline fuel pump comes on only after 3,000 RPMs. Of course you can buy a pill to make it come on whenever you want it to. I picked 3,000 RPMs because you can't here the pump at that point.
-JP
[Modified by quick108, 12:53 PM 12/26/2001]
stunnerone23
Oct 11, 2009 11:45 AM
conesmasher
Aug 11, 2004 05:18 AM
976
Dec 25, 2001 07:47 PM
dangerzone
Dec 9, 2001 09:35 AM
350z-tech
Nov 29, 2001 08:10 PM
