water wetter q
Re: water wetter q (civicb18b)
Congrats, u made me get off my lazy *** and grab the bottle from my garage, haha. I haven't used it yet cuz i wanted to flush my rad. system 1st. But i can tell you what the bottle says:
DIRECTIONS FOR USE: 1 ounce (3-4 cap fulls) per quart or 1 bottle per automotice cooling system of 12-20 quarts. Less than 50% antifreeze provides further improvement in temp. reduction, but atleast 15% antifreeze should be used in street vehicals.
I think only drag cars use only ww and water. Hope this helped.
Re: water wetter q (ThePunk)
get the royal purple **** its cools hell of alot better. I jsut run water in my car with that and its stays around 180-190
Re: water wetter q (b18bturbo)
I heard that you can use a couple of drops of liquid detergent and get the same effect as water wetter. Something about breaking the surface tension of water in the block which lets the water cling closer to the cyl walls and therefore pull more heat from cylinder. I don't want to be the first to try it and have soap bubbles coming out of the radiator
what is the royal purple ****? i'm pissed now because i just put in the WW, but i can always flush it and put in the better stuff...do you have the actual name for it? b18bturbo?
boostedcivicsir
09-07-2010 10:27 AM
