Water in turbo?
Old Apr 19, 2006 | 12:29 PM
alpha_1's Avatar
Default Water in turbo?
Well my head gasket blew and the water mixed with the oil. Since that water/oil mixture got into my turbo do the the oil feed line is my turbo still ok or is it trash now? please let me know.
Old Apr 20, 2006 | 01:40 PM
alpha_1's Avatar
Default Re: Water in turbo? (alpha_1)
bumb...someone let me know
Old Apr 20, 2006 | 02:12 PM
Brain3208's Avatar
I'd leave it. I would flush it out for a second(At most) of oil pressure buildup and then release the oil drail from the turbo into a pan to flush out the line. I really don't think it'll hurt anything else. Just how much water got into the Engine?
Brain
Old Apr 20, 2006 | 11:24 PM
alpha_1's Avatar
a good amout of water....so do u guys think the turbo is still good to go?
Old Apr 21, 2006 | 06:29 AM
Doodoo's Avatar
Default Re: (alpha_1)
How long did you drive with water/oil mix flowing through the turbo? I trashed mine because I had to drive about 5 miles home with a blown headgasket. Check for shaft play, in and out, up and down, side to side.
Old Apr 21, 2006 | 10:14 AM
alpha_1's Avatar
no driving...just started the motor up for 5 minutes and then shutted off because we didn't know what was wrong with the motor.
Old Apr 21, 2006 | 09:14 PM
alpha_1's Avatar
bumb for more help and info
Old Apr 21, 2006 | 09:34 PM
Frozen E's Avatar
H-T White Ops
You're fine. pour some oil in the feed line and let it run down. Then take some compressed air (30 psi max I'd say) and push that oil through the bearings so it drains out. Do this a couple times just to get all the old crap out of there.
But like I said, you're probably fine.
s2kseven
Dec 31, 2017 08:39 PM
dryhopsux13
Sep 29, 2004 05:39 AM
clutch33
Feb 1, 2004 08:55 AM
mojord
Apr 26, 2002 10:20 AM
