wastegate size?
Old Mar 19, 2005 | 10:36 AM
CRXTHIS's Avatar
Default wastegate size?
Gonna mod my hf manifold to run an external wastegate with my 14b. what mm wastegate should i run?
Old Mar 19, 2005 | 03:28 PM
platinum00's Avatar
Default Re: wastegate size? (CRXTHIS)
how much power are you looking to make,
normaly 38mm is fine..
Old Mar 19, 2005 | 03:41 PM
CRXTHIS's Avatar
Default Re: wastegate size? (platinum00)
probably less than 300
Old Mar 19, 2005 | 03:45 PM
platinum00's Avatar
38mm should be perfect.
if you want you can get 44mm and have alot of room for upgrade.
also depending on your mainfold design and where the wastegate is placed the bigger gate could help with boost creep.
i would say most people run a 38mm though. im running that on a hopefully so to be 350-400whp..
Old Mar 19, 2005 | 06:19 PM
manifoldmiketyson's Avatar
placment is more important, so make sure it you put it on the collector or near it.
karmadhi
Mar 8, 2014 11:42 AM
dave24
Mar 19, 2006 11:44 AM
97gsrki
Jan 21, 2006 09:22 PM
green91
Jul 16, 2004 06:00 PM
Spoold_R
May 13, 2003 05:21 PM
