wastegate question
alright heres the question. i am not really sure how a wastegate works, but if i am planning on running 20 25 psi of boost and my wastegate only has a 13 psi spring in it what will happen? will i never reach the 20 psi of boost i want and be cut off at 13 psi. please help me with how a wastegate works. thanx zack bower
if your wg has 13psi spring then that is what you run. If you have boost controller on that same wg then you can up the boost about 2 times the amount of your spring rating. So then if you are using lets say a MBC and you wnat to crnak it up to 20psi then you are okay using the 13psi spring.
You can never go lower than your spring rating in your wg
95srv
May 12, 2006 07:09 AM
Cyber ITR
Jan 19, 2004 03:38 AM
