wastegate question ?!?
Old Feb 14, 2003 | 11:34 AM
TriK's Avatar
Default wastegate question ?!?
i seen a couple of information about wastegate... and i am really dont know what to do ..
i sold all my old kit to make a better new one..
the question: the size of the wastegate ? more boost you push the size have to be bigger!??!? or.. more boost you push, less air have to come out from the manifold so a little one are better ??
i am confuse right now
Old Feb 14, 2003 | 12:44 PM
RAWB's Avatar
Default Re: wastegate question ?!? (TriK)
Me too
Old Feb 14, 2003 | 12:55 PM
civperc's Avatar
I had some definite trouble understanding your post, but I think I might have gathered what you are asking about.
if you run an external w.g. (maybe yours is Tial?) and you want to run, oh say, 7 psi; then you'll want to have a .45Bar spring in it (assuming your not utilizing a boost controller). Keep in mind that the spring rate translates into the lowest boost level you can run (again, assuming no b.c.), and once you reach the specified x.xx bar, then the w.g. will open and bleed out boost so as to prevent any boost creep or spikes.
hope that helped.
[Modified by untensadude, 9:57 PM 2/14/2003]
Old Feb 14, 2003 | 01:00 PM
Smashback's Avatar
Default Re: wastegate question ?!? (untensadude)
The Dude abides man, the dude abides.
Old Feb 14, 2003 | 01:13 PM
TriK's Avatar
Default Re: wastegate question ?!? (Hatchblack)
okay i have a boost controler and i boost 15-20 psi
since i boost more.. the wastegate have less air to push out the manifold..
so maybe it's better to have a small one?
sorry my english rush a little bit
Old Feb 14, 2003 | 01:26 PM
civperc's Avatar
Say friend, ya got any good sasparilla?
"H-T City sasparilla?"
Yeah, that's a good one
cool to see another TBL fan.
[Modified by untensadude, 10:27 PM 2/14/2003]
Old Feb 14, 2003 | 09:46 PM
TriK's Avatar
so its better a big one or a small one for big boost?!?!?!??!?!?!?!
my last was a 45 mm so..and a "!$!/"%! mega lag
Old Feb 18, 2003 | 10:33 PM
TriK's Avatar
agrr ?
Old Feb 18, 2003 | 10:41 PM
Stu's Avatar
Stu
New User
You need a bigger one for more boost. You are forgeting that everything you put into your engine also comes out. So.....the more you boost, the more you put out.
Old Feb 19, 2003 | 05:07 AM
EE_Chris's Avatar
Default Re: wastegate question ?!? (Stu)
Looking at TiAL's website, they say something contrary to what you have stated.
LINK See #2 for explanation.
Old Feb 19, 2003 | 07:10 AM
b16ahybrid's Avatar
Nope, you will have way more exhaust to expell at 20 psi of boost vs 5psi of boost.Your just expelling it later when you run more boost (takes longer to reach full boost). Since you have more flow you will need a larger wastegate. I.E a 40mm tial vs using a 35mm tial.
the wastegate just releases the exhaust before the turbo to control boost.
theo99gsr
Aug 1, 2005 09:11 AM
zbower7
Feb 6, 2004 09:48 AM
01ITR#700
Jun 22, 2003 10:01 AM
hybridb18
Dec 2, 2002 09:29 PM
DIRep972
Aug 18, 2001 03:34 AM
