wastegate question
Old Dec 20, 2002 | 05:50 PM
lowpsi's Avatar
Default wastegate question
I've already tried a search with no luck, so could someone please help..
Where can I find a diagram on how a external wastegate vacum hose should be ran w/o a boost controler..
really I need to make sure that there should be a hose going from the turbo to the side nipple on a delta wastegate...
thanks in advance......Z
[Modified by lowpsi, 2:51 AM 12/21/2002]
Old Dec 20, 2002 | 06:23 PM
lowpsi's Avatar
Default Re: wastegate question (lowpsi)
In other words where is the best place to get a vacum line for the wastegate??
thanks.......Z
Old Dec 20, 2002 | 07:06 PM
justinCO's Avatar
thanks.......Z
If your turbo has a fitting on the compressor housing then put the vac line from your WG there. If not just find another vacuum source that the WG can use by itself. For example my WG is on my brake booster vacuum.
Justin
Old Dec 21, 2002 | 01:48 PM
lowpsi's Avatar
Default Re: wastegate question (justinCO)
thanks..........Z
DaYZeD.1
Mar 28, 2008 06:54 AM
sykotic
Dec 4, 2004 09:49 AM
jwcardy
Sep 5, 2004 02:06 PM
VI Boost
Aug 9, 2004 05:29 PM
spike
Dec 30, 2002 12:36 PM
