Wastegate problems i beleve!!! HELP!!!!!!!!!!!!!!!!
K welll i notice my car is not building boost at all. I also notice that i have exhaust gases coming out my dumptube when idling. IS the wastegate going bad? What the hell can it be. It also a tial style 38mm wastegate from ss autochrome. So please help me out with this problem. Need to get my car running right by this weekend??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetaccord »</TD></TR><TR><TD CLASS="quote"> It also a tial style 38mm wastegate from ss autochrome. </TD></TR></TABLE>
there ya go. you should not have exh coming out at idle, also check your IC piping to make sure all is still attached together
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitsuman »</TD></TR><TR><TD CLASS="quote">
also check your IC piping to make sure all is still attached together</TD></TR></TABLE>
if exhaust is coming out of the dump tube, than its not an intercooler pipe problem.
either you dont have the fire ring in there, or the wastegate is bad. buy a real tial gate
my wastegate got stuck open once. i couldn't build boost at all. i finally just took it all the way up to 8k and it closed for some reason. lol but then it blew the gasket a couple weeks later. you should get the turbonetics fire ring style gasket from atpturbo for it too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">if exhaust is coming out of the dump tube, than its not an intercooler pipe problem.
either you dont have the fire ring in there, or the wastegate is bad. buy a real tial gate</TD></TR></TABLE>
start there.
start there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetaccord »</TD></TR><TR><TD CLASS="quote">word is was the fire ring. car running right now </TD></TR></TABLE>
Congrats.... that is some horrible typing though
well got the car tuned for 5psi. but the car is building 5 psi but it does not feel like it there. Its as if it struggling through the rpm band. What can it be?? I am thinking it injector(dsm 450) but i do not know for sure.
