Wastegate Problem
Old Jun 21, 2002 | 03:55 PM
B20-T's Avatar
Default Wastegate Problem
How do i know if my wastegate is not properlly working?thanks
Old Jun 21, 2002 | 04:13 PM
reXem's Avatar
Default Re: Wastegate Problem (turbob20)
Ummm...I think if you are either going over the boost you are set for or under it then the wastegate is not working....
Old Jun 21, 2002 | 04:21 PM
DragII's Avatar
25 Year Member
Default Re: Wastegate Problem (reXem)
Old Jun 21, 2002 | 07:28 PM
*Boostwerks*'s Avatar
no boost....
or too much boost....
then you will know.
Old smart chinese guy has spoken.
Old Jun 21, 2002 | 07:29 PM
rjardy's Avatar
Default Re: Wastegate Problem (Bryson)
hee heee
Rob
Old Jun 21, 2002 | 07:42 PM
Default Re: Wastegate Problem (rjardy)
To bad I'm a young stupid white boy
LOL!!!!!
[Modified by Bryson, 8:43 PM 6/21/2002]
Old Jun 21, 2002 | 07:59 PM
B20-T's Avatar
thanks guys..i got one more question..will a apexi vafc work on a non vtec motor?
Old Jun 21, 2002 | 08:02 PM
yes.
Old Sep 2, 2002 | 03:56 PM
accordfreak's Avatar
i am having a problem with my tial wastegate. i've had this wastegate for about a couple weeks and ever since i installed it, the wastegate opens very soon at 2.7psi! with my delta it was normal with 6.5 psi. i installed the ring that came with tial with no gasket since most of you guys aren't running one. what is the problem here? wrong spring on the tial wastegate??
oh and before i used to get only .1 bars before i moved the vac line to the throttle body!
please help! thanks.
[Modified by accordfreak, 12:59 AM 9/3/2002]
Old Sep 2, 2002 | 04:06 PM
Flamenco-T's Avatar
Default Re: Wastegate Problem (accordfreak)
do you have any boost controller ? if you don;t the wastegate will open prematurely and fully open at the preset spring rate...
EBC will hold all the pressure until the desire pressure is hit, then it opens..
stan
Old Sep 2, 2002 | 10:01 PM
Default Re: Wastegate Problem (Flamenco-NA)
but i bought the wastegate with a .45 bar spring... and right now it's reading .19bars... i don't know what's wrong... btw i don't have a boost controller.
thanks for your help.
Old Sep 3, 2002 | 11:54 AM
anybody????
Old Sep 3, 2002 | 04:34 PM
bmm89's Avatar
boost controller, even a cheap one, i think the tial needs one??? quick boost even with gain of only 20 on boost controller...
Mar 18, 2004 11:30 PM
aracer69
Jul 7, 2003 07:47 PM
turbo se
Jun 13, 2003 11:33 AM
whagkangmakulet
Oct 1, 2001 11:34 AM
