wastegate flange question!
Hey guys, Ive been told a 35-38mm 2 bolt wastegate flange will fit a 42mm progate...will it? If so, isnt the diameter of the 35-38mm like 1.3"? Myn is 2.0"
Thanks a lot!
Thanks a lot!
what brand wastegate? you mentioned 42mm progate so im assuming you are refering to turbosmart. the only problem is the turbosmart progate is 48mm and will not fit a 35/38mm flange. i dont know of any other "progates" or any 42mm wastegates at all so im a bit confused.
