Wastegate dump
Old May 26, 2004 | 07:06 AM
H.crx-si
Guest
Posts: n/a
Default Wastegate dump
Modified by H.crx-si at 8:53 PM 8/27/2005
Old May 26, 2004 | 08:07 AM
tgreaves's Avatar
Default Re: Wastegate dump (H.crx-si)
Thats so you can get to the wastegate valve if you need to.. The exhaust will exit around the valve and come out the opening to the left of the 3 bolt flange where your hand is..
If that makes sense..
Old May 26, 2004 | 08:59 AM
H.crx-si
Guest
Posts: n/a
Yup thats what I figured I can fit my fingers through the openings and see that the wastegate just dumps it with the exhaust. Just found it weird I havn't seen anyone else with the downpipe flange I will have to use
Old May 26, 2004 | 09:05 AM
tgreaves's Avatar
This should work..
http://www.atpturbo.com/Mercha...e=FLS
Old May 26, 2004 | 09:07 AM
H.crx-si
Guest
Posts: n/a
my inner diameter is just under 2inches so that wouldn't work but yeh thats the type of flange. Any muffler shop should have them.
Old May 26, 2004 | 09:09 AM
tgreaves's Avatar
Default Re: (H.crx-si)
2 inches... You might want to get some bigger exhaust there.. Just run 2.5" for the downpipe and then meet up to your 2" there..
Old May 26, 2004 | 09:16 AM
H.crx-si
Guest
Posts: n/a
no my exhaust piping is all 2.25 straight through but the exhaust/wastegate dump hole that my downpipe mounts to is only 2inchs across. This is a small turbo so I'm just gonna run a bigger size dp.
Cloneufc
May 13, 2009 05:57 PM
BanEL
Jan 31, 2005 05:23 PM
boondockgtr
Nov 13, 2003 10:00 AM
udctown
Sep 13, 2001 07:50 AM
