Wastegate actuator
Old Sep 6, 2008 | 05:00 PM
punkinbeck's Avatar
Default Wastegate actuator
I have a Weird *** turbo off of a dodge lancer on my F22 with an internal wastegate and the wastegate actuator is really close to the hood.. I just know its going to hit when i jump on it. Its a little over 2 1/2 inches OD. . Do any of you guys know can I get a smaller one that will do the same job?
Old Sep 7, 2008 | 06:20 AM
HiProfile's Avatar
Default Re: Wastegate actuator (punkinbeck)
2.5" is actually a small unit. Most OEM bulbs are 3" or larger.
The solution would be to lengthen the rod and put the actuator further in front of the turbo if space allows. Look at pics of the older SRT-4 stock actuator arms, that's basicly the shape you'll be attempting.
Old Sep 7, 2008 | 06:29 AM
punkinbeck's Avatar
sounds like a plan.. I see exactly what you mean about altering the rod and the bracket.. thanks
Modified by punkinbeck at 7:40 AM 9/7/2008
alex37211
Apr 8, 2009 03:50 PM
abmerop18
Jan 27, 2005 08:05 AM
1.8T_EG
Sep 20, 2002 03:44 PM
PolySquared
May 12, 2002 09:57 PM
