Want more power!!!!!!
Old Jul 13, 2003 | 03:24 PM
NOSED_CRX_VTEC's Avatar
Default Want more power!!!!!! with Dyno sheets
Can you guys please tell me how i can get more power
Had the car dyno'd and tuned but only got 200bhp at the flywheel
My setup is a stock B16A1 engine, revhard 2C kit, intank 255 pump, 450cc DSM injectors, MSD BTM, B&M FPR, 2.5" down pipe to stock cat and mid pipe to 2.5" custom made back box (Apex-i N1 muffler) running at 9psi
I would like to know what i can do to make more power, how much more power, and good and bad points for the mods.
open to any answers apart from SEARCH cos i did it and never got any good answers
Modified by NOSED_CRX_VTEC at 10:55 PM 7/15/2003
Old Jul 13, 2003 | 03:31 PM
alpha's Avatar
Default Re: Want more power!!!!!! (NOSED_CRX_VTEC)
Some work to the head?
Port Flow inner valve springs
ITR outer valve springs
GSR camshafts
If possible get rid of your cat.
DC2R714's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOSED_CRX_VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
open to any answers apart from SEARCH cos i did it and never got any good answers</TD></TR></TABLE>
How did you not find any good answers? Search for:
Standalone (hondata, AEM, haltech)
3in exhaust
That should help.
Old Jul 13, 2003 | 03:38 PM
Default Re: Want more power!!!!!! (DC2R714)
I could take out my cat cos i dont need it tested.
what sort of power will a standalone give me???
Old Jul 13, 2003 | 07:16 PM
BUMP up to the top for more answers
Old Jul 14, 2003 | 12:37 PM
wespirl's Avatar
You could build the bottom end.... but before I'd do that I'd just get a b18b block or b18c and start playing with that. The B16 block is tireddddd
Old Jul 14, 2003 | 01:06 PM
Pengo's Avatar
wait, is it just me or is 200 at the flywheel kinda low for a 9psi drag b16? i think you mean at the wheels, or at least i hope u do. seen some boosted sohcs make about the same power with 10-11 psi. who tuned ur car?
Old Jul 14, 2003 | 01:42 PM
psileepR's Avatar
New User
Default Re: Want more power!!!!!! (Pengo)
200hp is love for the kit..
post your dyno graph ... i smell a problem
what psi was your car tuned to?
Old Jul 14, 2003 | 02:00 PM
TeStUdO's Avatar
Default Re: Want more power!!!!!! (Civtek)
have you done a compression test lately?? 200 at the flywheel is not real high. id like to see a dyno sheet also
Old Jul 14, 2003 | 02:17 PM
NuclearB18B's Avatar
Default Re: Want more power!!!!!! (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">have you done a compression test lately?? 200 at the flywheel is not real high. id like to see a dyno sheet also</TD></TR></TABLE>
that's what i was thinking too
Old Jul 14, 2003 | 04:26 PM
I may found the problem!!!
I did a compression test and it's a little low
190-180-180-190
I'll post the dyno sheets tomorrow cos i got to scan them.
But I've taken the cat out and thats made a bit of gain (I think)
The cat was clogged to s**t with carbon.
Thanks for your posts and keep the ideas coming
Old Jul 14, 2003 | 07:23 PM
Quick 200k Mile Motor's Avatar
190 or 180 is not low for a compression test
Old Jul 15, 2003 | 01:50 PM
Here are my dyno sheets.
I'm running 9psi
The black line is what the motor had befor the tune
The red line is what the motors got now!!
Old Jul 15, 2003 | 02:06 PM
drvfast's Avatar
how much did the tuner retard the timing?
Old Jul 15, 2003 | 02:11 PM
Default Re: Want more power!!!!!! (drvfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drvfast &raquo;</TD></TR><TR><TD CLASS="quote">how much did the tuner retard the timing?</TD></TR></TABLE>
Not much something like 5deg because of the msd btm.
If I take of the btm how much should i retard the timing frim stock
Old Jul 15, 2003 | 04:08 PM
MaxBoost's Avatar
New User
I can tell you two things that will help you make closer to 250-280whp @ 9psi...
Hondata and Dyno Tuning
3" DP, TP, and Exhaust.
I'm looking at your setup, and something is definately wrong with that. I've seen people make alot more power then that w/ the same mods. There is sometihng wrong, so I suggest you get the above two mods, and go back to the dyno (perhaps to a better tuner), and have them look at it, and work out the bugs. don't settle for less then 250whp at 9psi!
Good luck!
levison
13
Dec 12, 2007 09:41 AM
dan's integra
May 4, 2006 10:20 PM
jmal1919
Jul 22, 2004 11:56 AM
BodyKits NW
Sep 28, 2003 07:53 PM
TwistedSI
May 17, 2003 03:31 PM
