want to get lower compression pistons
Old Jun 6, 2002 | 07:30 PM
Aeka GSR's Avatar
New User
Default want to get lower compression pistons
scared that my stock rings will go soon. I've been looking for some low compression pistons. I have a question. Will lowering compression effect emmissions?
Old Jun 6, 2002 | 07:38 PM
One20Two's Avatar
Default Re: want to get lower compression pistons (Aeka GSR)
Shouldnt Affect emissions, as long as the engine is assembled right, and the rings are set up to factory spec. Could actually reduce emissions, at lower RPM as long as y our fuel is set right as well
I wouldnt worry about it
Old Jun 6, 2002 | 08:48 PM
Aeka GSR's Avatar
New User
thanks
Old Jun 8, 2002 | 07:21 AM
One20Two's Avatar
No prob man, just make sure you let the engine builder know that you need it to pass emissions, and you would like the piston ring tolerances to reflect that. And if it is you building it, just follow a fatcory manual to a tee.
Later!
BTW: I have a 95 GSR Turbo, and I am thinking of doing the same, let me know how it comes out. Ive been running 10 psi for 2.55 years, so Im pretty close to rebuilding as well
[Modified by One20Two, 4:22 PM 6/8/2002]
VVENOM800TT
Feb 17, 2011 02:48 PM
90efhatch
Sep 8, 2010 07:47 AM
EK9 CTR
Oct 4, 2008 12:27 PM
I_know
Dec 21, 2002 07:07 AM
*Boostwerks*
Oct 10, 2002 04:43 AM
