Walbro 400 fueling issue
Old Aug 29, 2016 | 05:09 PM
Psychoteen101's Avatar
Default Walbro 400 fueling issue
Having some fueling issues, not sure exactly what the cause is. Trying to get some feedback if anybody has any ideas. Turbo k20 in an eg. Running a walbro 400 on the stock hanger, ID 2000s and e85. When my tuner was running the car on the dyno, it started running lean below a half tank of fuel. Added fuel in kpro and did nothing. Kept adding fuel and kept running lean. Car on high boost was only at 60% duty cycle for fuel. Added 5 gallons of fuel and all the fuel he added came into play and started running super rich. On the street it's the same thing. Just below half a tank, it acts like its running out of gas, sputtering, ect. I know the sending unit is reading correctly cause when I fill it up, it only takes like 4 or 5 gallons. Pulled the pump out of the tank and everything still looks fine. Not sure if something is wrong with the pump maybe? Any input would be great. I ran the pump with pump gas a couple seasons ago and it never had a problem. Runs great above half a tank of fuel.
Old Aug 30, 2016 | 04:55 PM
V-SPEC 1's Avatar
Default Re: Walbro 400 fueling issue
I know U already said U pull the pump back out but did u inspect the rubber hose? mine was busted and I was wondering why I wasn't getting pressure.
Old Aug 31, 2016 | 07:03 AM
LightningTeg's Avatar
Community Builder
Are you monitoring fuel pressure in anyway? Is this the E85 compatible version pump?
My last "450" started to not hold pressure above waste-gate boost when I tuned it on the dyno. Ended up having to buy a new pump, never really opened it up to see what was wrong, but the new pump was much better sounding.
Old Aug 31, 2016 | 09:20 AM
pogeeboy27's Avatar
How long did your 450 last you? And what pump are you running now?
Old Aug 31, 2016 | 10:20 AM
Community Builder
3 Years, and replaced with same pump.
Old Aug 31, 2016 | 05:20 PM
Didn't look at the hose super close. Looked intact when I had the pump out, but I'll check again. Car runs great with a full tank of fuel at any boost level so I doubt pressure is dropping out. The gauge is under the hood so I can't keep an eye on it other than at idle. Pump is e85 compatible. Not sure whether I wanna try a new pump or just wait and sump the tank and run an inline pump for next season.
Old Sep 1, 2016 | 05:33 PM
V-SPEC 1's Avatar
My car would do the same, It will start leaning out after about under half tank. I'm on e85 daily driven NA setup though.
Old Sep 3, 2016 | 08:33 PM
92cxyd's Avatar
did you put in a stock length sock, the one that comes with these pumps are too short.
you will have fueling issues like this if not addressed, also look and see if the oem rubber fuel lines are not swollen on the inside ans restricting flow.
Old Sep 9, 2016 | 10:47 AM
It's been a while so I don't remember if I reused the old sock or used one that came with the pump. And I'll check the hose this weekend. Thanks for the input
Silvertc
Feb 16, 2010 12:56 PM
1FSTHATCH
Dec 11, 2005 09:50 PM
00000xxx
May 22, 2005 04:41 PM
91integraLSVTEC
Oct 26, 2003 07:52 PM
BLKCRX
Sep 12, 2003 08:14 AM
