Wahts wrong with the OBX manifold
Old Jun 16, 2003 | 08:48 AM
tx99gsr's Avatar
Default Wahts wrong with the OBX manifold
I've heard people say on this board and others not to use the OBX exhaust manifold, and I was just wondering why?
Old Jun 16, 2003 | 09:15 AM
Boltz's Avatar
it will crack....too bad it looks nice though.
Old Jun 16, 2003 | 09:18 AM
mamaboy's Avatar
Default Re: Wahts wrong with the OBX manifold (tx99gsr)
bad material....very prone to cracking (ie. your wastegate falling off and landing about 500 ft behind you before you even realize that loud noise was from that). be patient and purchase yourself the RevHard equal length...I believe the look the same...if that's what you want....or go with the InlinePro / RevHard manifold. I've heard RevHard cracking on rare occasions, but the InlinePro is cast so it's quality is top notch....PM Arturbo he sells them
tx99gsr's Avatar
Default Re: (Civic420)
man that is to bad, because it's a vary nice looking header for the price!
Old Jun 16, 2003 | 11:30 AM
mike1114's Avatar
Default Re: (tx99gsr)
tinker219 on here can make a mani for you too!
Old Jun 16, 2003 | 11:36 AM
GreddySi99's Avatar
Default Re: (mike1114)
those OBX and spark racing manifolds all crack.
Old Jun 16, 2003 | 05:03 PM
tx99gsr's Avatar
Default Re: (intercooledJRSC)
Seems like I've heard that ether drag or rev hard one of the two tend to crack as well is true?
Old Jun 16, 2003 | 05:12 PM
TREVER's Avatar
I think spark will warranty there's now. There newer manifolds seem better
Old Jun 16, 2003 | 05:13 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tx99gsr &raquo;</TD></TR><TR><TD CLASS="quote">Seems like I've heard that ether drag or rev hard one of the two tend to crack as well is true?</TD></TR></TABLE>
alot of people have cracked drag mani's. never had problems w/ mine
Old Jun 16, 2003 | 05:46 PM
TKERacer619's Avatar
Default Re: (TeStUdO)
I dont think the OBX will crack if it's properly supported. It's just a lot of weight out there.
Old Jun 16, 2003 | 11:42 PM
RuthlessEF-9's Avatar
Default Re: (TKERacer619)
i agree i think the mani can support a small turbo... not some huge *** 60-1
Old Jun 17, 2003 | 12:14 AM
XDEep's Avatar
Default Re: (D16z6turbs)
ya dont rule out proper support as a fix. but whos gonna test it..
Old Jun 17, 2003 | 01:40 PM
scooter's Avatar
Default Re: (XDEep)
I will test, gonna put a T3/T4 on it and support it and see if it holds.
scott
Old Jun 17, 2003 | 02:08 PM
gsrt's Avatar
Default Re: (scooter)
no it will not hold. i have a newest one and i support it. it was crack in 2 month but i reweld it. i can e-mail picture if you want.
Old Jun 17, 2003 | 05:33 PM
Default Re: (gsrt)
Yes please post pics. I would like to see how the manifold is supported
Old Jun 17, 2003 | 05:56 PM
Jared's Avatar
FYI, because of a friend's experience and those posted on here, I decided against the OBX and just ordered one from Tinker219 aka LoveFab.
Old Jun 17, 2003 | 05:59 PM
mike1114's Avatar
Default Re: (Jared)
ME TOOOOO!!!!!!
Old Jun 17, 2003 | 09:32 PM
XDEep's Avatar
one or two re-welds doesnt bother me much.. as long as its still cheaper than others. my neuspeed 421 cracked and i dont blame the company really, as im sure it took one or two too many bumps/bottoming out.
Old Jun 17, 2003 | 09:38 PM
boosted hybrid's Avatar
Default Re: (XDEep)
The problem isnt the material per say. Its 10 gauge 304 stainless. Its the welding that is done the manifolds. When you have a TIG weld you have to penetrate the entire way through the pipe to make a complete weld. This must be done with Argon being purged into the piping being welded so that the inside AND outside of the piping is shielded properly. If this doesnt happen, "sugaring" will occur to the weld on the inside. The weld becomes nothing more than a cosmetic piece, and cracking will occur. The TIG welds on the manifolds are preformed by robotic machines, incapable of knowing if they have welded all the way through the piping or not, as well as telling if "sugaring" has occured. I have one of the sparkz racing manifolds, the welds are purely cosmetic and there is "sugaring" over the entire inside of the collector area.
Old Jun 17, 2003 | 09:56 PM
XDEep's Avatar
Default Re: (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">The problem isnt the material per say. Its 10 gauge 304 stainless. Its the welding that is done the manifolds. When you have a TIG weld you have to penetrate the entire way through the pipe to make a complete weld. This must be done with Argon being purged into the piping being welded so that the inside AND outside of the piping is shielded properly. If this doesnt happen, "sugaring" will occur to the weld on the inside. The weld becomes nothing more than a cosmetic piece, and cracking will occur. The TIG welds on the manifolds are preformed by robotic machines, incapable of knowing if they have welded all the way through the piping or not, as well as telling if "sugaring" has occured. I have one of the sparkz racing manifolds, the welds are purely cosmetic and there is "sugaring" over the entire inside of the collector area.</TD></TR></TABLE>
ya i always wondered how people can tell if a weld has gone through, either too much or not enough. especially with those wierd pipe angles.
Old Jun 18, 2003 | 02:49 AM
turboex's Avatar
I run an ss autochrome/OBX one on my sr20det. The walls are alot thicker than i thought they would be. Very nice unit, I have an hks2530 not a big turbo but bigger than stock and i have had the mani for 9 months and hand no priblems at all. I payed 280bucks. In the land of the sr20det where manis cost a grand or more i think this one is well worth the money. Only bad things is pulling the mani on an s13/sr20det is 100 times harder and longer to do than the onld hond ai had. Damn nissans
Old Jun 18, 2003 | 06:34 AM
AP-Signworks1's Avatar
The new designs seem very different from the older designs. I got one for our project car before I found out about all the horror stories. This one is supported on the bottom. From the flange to the collector, there are two supports. And the WG flange is much closer than the pics I see of the cracked ones. There's hardly any pipe there at all, just the WG flange. Hopefully this works out since it's on the car already.
On the plus side, we put the car on the dyno right after finishing it, and it put down 160.6 whp and 135.9 ft/lbs at 3psi, running way rich (A/F was around 10 the whole time). This is on a '00 Integra LS auto. Can't wait to break everything in, put it back on the dyno and tune it.
Old Jun 18, 2003 | 06:32 PM
boostedsi1's Avatar
Default Re: Wahts wrong with the OBX manifold (AP-Signworks1)
I just bought the OBX Turbo Manifold for My Si and I will be welding two support brackets on the bottom of the manifold for support. I'll let you know how it goes. Thanks.
Old Jun 18, 2003 | 06:49 PM
boosted92's Avatar
Default Re: Wahts wrong with the OBX manifold (mamaboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mamaboy &raquo;</TD></TR><TR><TD CLASS="quote">bad material....very prone to cracking (ie. your wastegate falling off and landing about 500 ft behind you before you even realize that loud noise was from that). be patient and purchase yourself the RevHard equal length...I believe the look the same...if that's what you want....or go with the InlinePro / RevHard manifold. I've heard RevHard cracking on rare occasions, but the InlinePro is cast so it's quality is top notch....PM Arturbo he sells them</TD></TR></TABLE>
Can you show me where I can buy a revhard equal length? Somebody on here had an SI before that was making a bunch of horsepower with one, but I havn't found one for sale. Been thinking of the inlinepro one too, that's a nice piece as well.
Agtronic
Welding / Fabrication
69
Aug 22, 2009 12:10 PM
boostincoupe
May 21, 2006 07:49 PM
eg2turbo
Oct 31, 2003 07:49 PM
InTeGrA B18b1
Mar 23, 2003 03:53 PM
tegasaurus
Feb 21, 2003 11:23 AM
