vortech supercharger
Old Nov 2, 2005 | 05:11 PM
DJ_Toocrazy's Avatar
Default vortech supercharger
i have a k20 type r in my 93 hatch and i want a little more power under the hood.
i was wondering if it was possible to buy a integra type r vortech supercharger and put it on my k20 type r, since they dont make them for rsx's and i dont want a turbo so i was wondering if that would work, but of course its just another crazy idea
Old Nov 2, 2005 | 05:14 PM
JDMlyfestyle's Avatar
Might as well get a Jackson Racing supercharger
BTW check out K20a.org
Old Nov 3, 2005 | 03:30 PM
Default Re: (JDMlyfestyle)
yea but jacksons superchargers doesnt give the horsepower and the torque that vortech does...i want a vortech
Old Nov 3, 2005 | 03:32 PM
. O M E G A's Avatar
3rd g3aR vTak
Default Re: vortech supercharger (DJ_Toocrazy)
How much was that swap? Any more then a B16? OH . . . . I believe Vortech is working on one , but I don't know if it will work on swapped motors.
Old Nov 3, 2005 | 04:02 PM
A.E Motoring's Avatar
Default Re: vortech supercharger (omega02379)
YAY FOR VORTECH, hahaha, i kind find out more info on the k series SC, i work there, so i can see wats up, see if they have one in production
Old Nov 3, 2005 | 04:03 PM
3rd g3aR vTak
Default Re: vortech supercharger (SPNFEDEJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEJ &raquo;</TD></TR><TR><TD CLASS="quote">YAY FOR VORTECH, hahaha, i kind find out more info on the k series SC, i work there, so i can see wats up, see if they have one in production</TD></TR></TABLE>UUUUUUUHHHHH , HOOK UP ?
Old Nov 3, 2005 | 04:05 PM
lol
Old Nov 3, 2005 | 04:41 PM
cybergreencivic's Avatar
just go turbo then if they dont make a vortech yet. will b just as good a setup
Old Nov 3, 2005 | 04:48 PM
b16sedan's Avatar
Default Re: (DJ_Toocrazy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_Toocrazy &raquo;</TD></TR><TR><TD CLASS="quote">yea but jacksons superchargers doesnt give the horsepower and the torque that vortech does...i want a vortech </TD></TR></TABLE>
The Vortech also gives you that ultra peaky powerband with no mid range/low end that the JRSC doesn't give you. Oh, wait. That isn't a good thing..........
Old Nov 3, 2005 | 05:00 PM
Default Re: vortech supercharger (cybergreencivic)
SPNFEDEJ what do you do at vortech?
Old Nov 3, 2005 | 05:02 PM
build FMU's by pass valves, fuel pumps and ****, charge pipes, after coolers, innercoolers, and wat not, i do a bunch of various things, pulleys, belts...blah blah
Old Nov 4, 2005 | 03:50 PM
SPNFEDEJ i looked at the site but i dont think they had anything for a rsx just a 99-00 civic si and integra GSR and TYPE R so i was wondering if it would be possible for the integy type r sc in my k20 type r engine
Old Nov 4, 2005 | 03:56 PM
david@didrace.com's Avatar
4 cylinders and superchargers don't mix. A Paxton Novi-2000 takes almost 75whp just to turn! Is your four cylinder able to sacrifice power down low? I didn't think so.
Old Nov 4, 2005 | 05:41 PM
Default Re: vortech supercharger (rota92)
yea, were not making one for the k series, not as right now at least
Old Nov 5, 2005 | 04:02 AM
madhive's Avatar
If you want a supercharger you'd be better off with a JRSC because a Vortech is all top end.
Plus a Vortech doesn't hit full boost till redline.
Old Nov 5, 2005 | 04:38 AM
smokinsi's Avatar
Default Re: vortech supercharger (madhive)
A jackson gives a little more umph off the line with putting around not trying to race. But when the revs are up like you are really trying to race the Jackson doesn't stand a chance against Vortech. With tunning you can easily take the vortech to levels unheard of by Jackson.
Old Nov 5, 2005 | 06:41 PM
Default Re: vortech supercharger (smokinsi)
ok so could you tune the vortech sc to run like a jackson racing sc but still have the power of vortech at high rpms? i dont want to sacrifice low end horsepower and i want that pull that jackson racing sc give you just while cruising but want that massive power from a vortech while racing
Old Nov 5, 2005 | 07:11 PM
b16sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_Toocrazy &raquo;</TD></TR><TR><TD CLASS="quote">ok so could you tune the vortech sc to run like a jackson racing sc but still have the power of vortech at high rpms? i dont want to sacrifice low end horsepower and i want that pull that jackson racing sc give you just while cruising but want that massive power from a vortech while racing</TD></TR></TABLE>
No. A JRSC makes full boost the instant you go WOT. A Vortech makes boost that looks like a logarithmic curve, JRSC is instant. That's why the JRSC has such a huge mid range and low end power advantage over the Vortech, and is the reason why the Vortech just wasn't awfully fun to drive on a small displacement motor. No amount of timing or greater compressor efficiency is going to make up for a poor design.
Old Nov 6, 2005 | 06:43 AM
madhive's Avatar
You might want to go with a ball bearing turbo like a GT28rs which gives you good low/mid and high end pull.
vietnamezerice
Sep 29, 2007 09:22 AM
Squirtin EGsr
Dec 9, 2005 03:11 PM
brasilianstreet
Sep 22, 2004 08:02 PM
hooptie157
Mar 19, 2002 10:10 AM
AllMotorITR
Aug 8, 2001 05:38 PM
