vortec FMU question
Old Jul 7, 2004 | 03:56 AM
h22vtecmonster's Avatar
Default vortec FMU question
I'm buying a vortec FMU off my boi, hw doesn't know what ratio it is, is there a way to tell what it is ,10:1, 12:1, 4:1 ect. just by looking at it and where. thanx for any help.
Old Jul 7, 2004 | 12:58 PM
eric98gsr's Avatar
Default Re: vortec FMU question (h22vtecmonster)
Depends on where he got it from. If it is from a drag kit, I know it's 12:1.
Old Jul 7, 2004 | 06:10 PM
Cee_mon's Avatar
Default Re: vortec FMU question (eric98gsr)
They should have a product number stamped right into the unit. On mine it never said Vortec or anything....just the code. I did a search and found out it was a Vortec 12:1. Hope this helps.
Old Jul 8, 2004 | 12:19 AM
well obviously this unit is the color blue and it has vortec writen in about two places. but I'm not sure where it came from. my boi got it off our other boi that just put together a custom kit, so no telling where he got it form, i'll look at it in the morning when I get off work. I'm going to be running a stock block d16z6 w/ 16G turbo walboro fp, and dsm 450 cc inject. what ratio type FMU would I need. 12:1, ect. or does it matter. any suggestions would help.
Old Jul 8, 2004 | 12:47 AM
thatguy's Avatar
Default Re: (h22vtecmonster)
boi is spelled boy just fyi. I would really suggest not using an FMU. You will have a lot better running car by using a real engine management system such as hondata.
Old Jul 8, 2004 | 04:11 AM
b18b98's Avatar
if the disc inside is as big as the cover then it is a 12:1. If its a little bit smaller it is a 10:1 and so on and so forth.
Old Jul 8, 2004 | 08:41 AM
TURBOED-TEG's Avatar
You don't I repeat DO NOT want to use an fmu when running 450cc injectors...you will be EXTREMELY rich and will have no way to trim the fuel back.
COLORPROS
Mar 11, 2003 04:47 PM
rbf351
Nov 26, 2002 09:26 AM
_Endless_
Nov 3, 2002 09:39 AM
Hybrid
Aug 9, 2002 03:14 PM
