Victor x Mainfold users question
Old Sep 13, 2009 | 12:38 AM
oodie's Avatar
Icon2 Victor x Mainfold users question
Im running into so many small problems. I have manifold with inlinepro fuel rail but stock fuel pressure regular wont fit hits the second runner. Its a straight egded GSR regulator is what i have. What are my options i know that the Ls motors use one that has a bend in it I was told this would work. Has anyone done this or if they used aftermarket one which brand. Any help would be appreciated Thanks
Old Sep 13, 2009 | 12:54 AM
Redline130's Avatar
Default Re: Victor x Mainfold users question
I use an Aeromotive FPR. I had it mounted on the end of the fuel rail, but have since relocated it to the firewall. I know what you mean about not having enough space.
Old Sep 13, 2009 | 05:18 AM
Muckman's Avatar
Moderator in Chief
It will clear if you flip the stock GSR regulator upside down. I know its gay but thats actually what the Edelbrock instructions say to do. Your other options include remove mounting an aftermarket regulartor or buy an ITR regulator which clears the normal way on the end, which is what I did.
Old Sep 13, 2009 | 06:32 AM
Bailhatch's Avatar
I used a b16 one and just bent it a little.
Old Sep 13, 2009 | 08:51 AM
Desir Performance's Avatar
I believe Golden Eagle makes an adapter for just that problem.
Old Sep 13, 2009 | 10:52 AM
Garage 808 Hatch's Avatar
You can use the stock one with the 90* in it, also an AEM one, and there is a 90* fitting that works on the AEM, same with the Aeromotive rail mount regulator, same 90* fitting works on it too, i believe its made by XRP
Old Sep 13, 2009 | 12:11 PM
cjordan's Avatar
Aeromotive fire wall mount here, have heard of people running the ITR as stated above also though
Old Sep 13, 2009 | 06:34 PM
YARO.'s Avatar
I have the stock one with the 90* bent on the bottom works great. I also installed a b&m adjustable cheap way to make it work good. Can go with a aeromotive remotely mounted on the firewall for ballerness lol
Old Sep 14, 2009 | 06:03 AM
EARLdaSQUIRREL's Avatar
official honda whore
use the golden eagle adapther that flips it 90*, i have one for 15 shipped if you want it pm me
jdmboy94
Dec 25, 2008 05:01 PM
Schister66
Jan 5, 2006 06:37 PM
*Boostwerks*
Feb 15, 2004 08:32 PM
TroyL
Oct 30, 2002 08:15 PM
