Very odd problem with GSR just developed..
Old Dec 3, 2003 | 08:15 AM
VTC_CiViC's Avatar
Default Very odd problem with GSR just developed..
Had a very odd thing happen to my yesterday. On the way to the video store, the car was behaving perfectly fine, but on the way home I noticed when I'd approach 4k rpm the car would sputter tremendously and refuse to climb in rpm. If I tipped the throttle more than 60-70%, the injectors would shut down completley untill I let off the throttle and the car would resume idle. Again, this is only if you tip the throttle hard and begin to boost or are around 4k rpm, has anybody heard of anything like this? Does Hondata have a limp mode with a low rev limiter? The CEL has been on for some time, though whenever I try to pull the code by jumping the service plug, the light won't flash and give me the code so I'm kinda stuck here. Any ideas??
Old Dec 3, 2003 | 09:03 AM
HXMan's Avatar
Default Re: Very odd problem with GSR just developed.. (VTC_CiViC)
Sounds like it may be the famous hondata hesitation.....
Old Dec 3, 2003 | 09:09 AM
VTC_CiViC's Avatar
Default Re: Very odd problem with GSR just developed.. (HXMan)
Nah, this isn't just hesitation, this is something very different.
Old Dec 3, 2003 | 09:10 AM
dabrown's Avatar
I am having the same problem intermittently with my wife's hondata. I reset the ecu and it has not come back as of yet.. Possibly hondata but hopefully a tuning guru will help us understand.. The weird thing is that I can not get a code when the Check Engine light comes on..
Old Dec 3, 2003 | 09:30 AM
ladysman's Avatar
Default Re: Very odd problem with GSR just developed.. (dabrown)
If you unplug the interface box to the ECU you get a 4000 rev limit. Check the cable.
Old Dec 3, 2003 | 09:35 AM
mike1114's Avatar
Default Re: Very odd problem with GSR just developed.. (ladysman)
yea it sounds like a cable connection, I'm no hondata guru but from what I've read this sounds like it.
Old Dec 3, 2003 | 09:45 AM
Rory Breaker's Avatar
Exactly...not only that, but a solid CEL would indicate an ECU problem.
Something is not right with the connection to the Hondata. No Hondata = CEL & 4K revlimit.
Old Dec 3, 2003 | 09:49 AM
dabrown's Avatar
Default Re: Very odd problem with GSR just developed.. (mike1114)
LOL. That makes sense. The hondata is in the glove box and I haven't secured it well. Will run down and get some Velcro after work.
Old Dec 3, 2003 | 10:28 AM
VTC_CiViC's Avatar
Ok well, I left Frank at SFP a message so i'll be waiting for him to get back to me. Like I said, the CEL has been on since I picked up the car and I've never been able to pull a code. I've reset the ECU and it still stays on. I'll recheck the ECU-->Hondata connection tonight and see if I can resolve anything, thanks
Old Dec 4, 2003 | 06:36 AM
VTC_CiViC's Avatar
Alright so get this guys, I played around with the Hondata --> ECU connection, nothing doing, still have a solid CEL. I went ahead and removed the Hondata/P28 altogether, and plugged up the stock P72, turn the key and viola! No CEL... remove the P72 and swap the P28 back in, solid CEL
Whatever the problem is, it seems to be surrounding the P28 yet the car is driving fine now. Any idea?? Is the S200B any different in operation than previous Hondata's? I ask because I unplugged the bluebox from the ECU while driving and I was able to boost the car perfectly, plug it back in and no change. Whatever was causing the 4k limter/sputter is gone (probably a loose connection) but the CEL is still alive and kicking....... anybody experience anything like this??????
Old Dec 4, 2003 | 06:44 AM
TurbodCX's Avatar
Dave,
What is the code that the P28 is throwing? Is it code 1? or is it the No flash code?
I still think you have a problem with one of the ROM chips or with the box its self.
Brian
Old Dec 4, 2003 | 06:50 AM
VTC_CiViC's Avatar
Default Re: Very odd problem with GSR just developed.. (TurbodCX)
Solid CEL, no flash code. My understand is that it's a "0" which is general PCM failure, yet my car runs like a champ?
And of course nobody at SFP has called...
Old Dec 4, 2003 | 07:27 AM
TurbodCX's Avatar
Usally when it does that there is a connection error, with either a ROM chip or one of the cables. I have had mine do this before, and on one instance it was the little blue box,which i had to send back to hondata to be repaired.
Brian
Old Dec 4, 2003 | 08:06 AM
dabrown's Avatar
Dave, I am trying to get a hold of Hondata to unlock my datalogging so I can find out what happens when the code flashes. By the way anyone know the Hours of Hondata? I called but no answer and the hours aren't online.
Old Dec 4, 2003 | 08:21 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dabrown &raquo;</TD></TR><TR><TD CLASS="quote">Dave, I am trying to get a hold of Hondata to unlock my datalogging so I can find out what happens when the code flashes. By the way anyone know the Hours of Hondata? I called but no answer and the hours aren't online.</TD></TR></TABLE>
10-5 PST
Old Dec 4, 2003 | 08:23 AM
VTC_CiViC's Avatar
Old Dec 4, 2003 | 09:08 AM
dabrown's Avatar
Alright.. I think my problem has something to do with Auto A/C on and off feature. The car did not throw a cell but it did have the 3000 rpm blip. I LOVE the datalogging on this thing.. The AC light pops on and off when I get the blip while cruising partial throttle. I am reviewing the recorded datalogger as we speak.. Not to get off topic but the datalogging would have been perfect for tuning.. It shows what cells you are at while driving for fuel and timing. I am using Crome for my car now, but I am going to research for the Datalogging option made by the same person who created Crome. I will keep you posted on the fix..
Zaraki
Engine Management and Tuning
Oct 28, 2013 07:17 PM
ef2hondaboi
Jul 21, 2009 06:42 PM
Nfurno
Sep 1, 2004 12:42 PM
Aeka GSR
Apr 28, 2004 09:26 AM
AlphaKennyWun
Oct 15, 2002 04:33 AM
