valves/pistons for sprayed ls vtec?
Old Dec 17, 2007 | 06:38 PM
dc2leftovers's Avatar
Default valves/pistons for sprayed ls vtec?
im going to be running an lsvtec w/ direct port 100 shot and i was planning on going 10:1 compression does anyone have any ideas for pistons to use for this setup as well as valve material or brands??
thanks
Old Dec 18, 2007 | 01:51 PM
nitrousballa's Avatar
Default Re: valves/pistons for sprayed ls vtec? (dc2leftovers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2leftovers &raquo;</TD></TR><TR><TD CLASS="quote">im going to be running an lsvtec w/ direct port 100 shot and i was planning on going 10:1 compression does anyone have any ideas for pistons to use for this setup as well as valve material or brands??
thanks</TD></TR></TABLE>
as far as pistons,i would go with cp,wiesco,arias.for the valves i would go
ferrea or manley.
Old Dec 19, 2007 | 06:29 PM
Default Re: valves/pistons for sprayed ls vtec? (nitrousballa)
should i buy any sort of special piston ive heard some have like special coatings for nitrous or something and what about valve material? (SS, titanium, etc.)
Old Dec 19, 2007 | 06:37 PM
tegman23's Avatar
manley vavles and wiesco pistons
Old Dec 19, 2007 | 06:54 PM
nfn15037's Avatar
Default Re: (tegman23)
I would run higher compression or a bigger shot. High compression loves nitrous oxide. But as stated any good forged piston will serve you well, I prefer CP, JE, or Arias. A Swain coating or the like (Tbone does good coatings) would be nice on the piston top, and so would an anti friction skirt coating, but many engines have been run successfully for many miles and passes at the strip without fancy coatings.
Old Dec 20, 2007 | 03:42 PM
Default Re: (nfn15037)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">I would run higher compression or a bigger shot. High compression loves nitrous oxide. But as stated any good forged piston will serve you well, I prefer CP, JE, or Arias. A Swain coating or the like (Tbone does good coatings) would be nice on the piston top, and so would an anti friction skirt coating, but many engines have been run successfully for many miles and passes at the strip without fancy coatings.</TD></TR></TABLE>
nitrous does love higher compression...but it also takes more of
it to reap the benifits of it also.when you have forged parts it allows for-
giveness if the tune is not right and allows you to make it right.but
sometimes w/forged parts you don't get SECOND CHANCES either.
Murk 'EM
Apr 30, 2009 11:34 PM
HondaBurger
Sep 19, 2007 02:36 PM
Rhythm
Mar 19, 2006 07:33 PM
ToFu-DeLiVeRy
Sep 20, 2004 06:57 PM
96SR-V
Mar 22, 2003 06:48 AM
