Valves
Old Apr 10, 2003 | 10:48 AM
Riptide101's Avatar
Default Valves
I would use the search fuction but it doesn't work so please don't slam me. I am just wondering what after market valves are people on this board using or if they heard anything about specific valves ie Ferrea or Crower. Those are the 2 that I am really looking at. Plan on buying monday so I am waiting on responses from you guys and girls to make my decision. Any info good or bad I would appreciate.
Ferreas are more expensive compared to the crowers but the difference isn't enough to worry me.
Old Apr 10, 2003 | 11:04 AM
93LSivic's Avatar
Default Re: Valves (Riptide101)
I have Ferrea and havent had a problem with them. Havent had the motor apart after the build so i couldnt really inspect them, but nontheless ive had no problems so far.
I would just suggest if your going to do valves then you might as well go oversized, price doesnt change at all.
Old Apr 10, 2003 | 11:48 AM
Riptide101's Avatar
Default Re: Valves (93LSivic)
Don't you have to do headwork to support biger valves
Old Apr 10, 2003 | 01:19 PM
boosted hybrid's Avatar
If you go with .5mm oversized valves, then you dont have to open up the valve reliefs in the head. 1mm or larger you'll have to have them opened up. If you are going with larger valves, the entire head has to be a system to take advantage of the larger valve. Larger throttle body, port and polish, higher lift cams, etc will so the real benefit of the larger valve.
Old Apr 10, 2003 | 01:23 PM
b18bturbo's Avatar
Default Re: Valves (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">If you go with .5mm oversized valves, then you dont have to open up the valve reliefs in the head. 1mm or larger you'll have to have them opened up. If you are going with larger valves, the entire head has to be a system to take advantage of the larger valve. Larger throttle body, port and polish, higher lift cams, etc will so the real benefit of the larger valve.</TD></TR></TABLE>
well put just adding vlaves wont help that much need a compelte job done on the head
junkyard racer
Sep 7, 2008 04:41 PM
Boostage
Sep 15, 2005 05:35 PM
BigPlansNoMoney
Nov 2, 2004 06:45 PM
Allstar
Apr 30, 2002 07:54 PM
Smoothy
Sep 23, 2001 05:38 PM
